How do I get the lower fan pulley off (6 rib)
There are larger diameter threads that the bolt that holds to flywheel goes through, so wondering if I just screw a bolt into that it'll push off?
..don't mind the pink dots, i use to first pass install degree wheel.
What does Clewett say?
Racer
Heat it up.....
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
There is a special tool that screws into the larger threads and has pointed end for the crank side
Made out of softer metal to not mess up anything you can buy them from like baum tools not To expensive |
Thanks... figured out “push off threads” Are 16mm fine so I just got bolt that fits and I’ll cut piece of brass punch to put in front of bolt and use that to push on crank.
