head studs losing their torque on 3.3 turbo
I assembled a 3.3 turbo motor a few years back using ARP head studs. Every 1,000 miles or so I need to re-torque the heads. When I check the torque it will be down to 10 lbs or so. The studs aren't pulled, and the heads torque down to 30lbs.
Any suggestions on how to fix this?
Harold '79 930/DP935 (sold) '68 VW 3.3 Turbo Crewcab |
I would rather be driving
ARP recommends 38 ft-pounds torque using their lube. This might help.
https://tech.arp-bolts.com/instructions/204-4206.pdf My current build is still torqued after 600 miles. its a NA engine but no problems with torque.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
The initial torque was to 38 ft lbs. with their lube. When they came loose the first time, Henry @Supertec suggested 30 lbs.
Ingenieur
Did you Loctite the studs into the case?
I presume you are using the ARP washers and flange nuts? Did you mark the angle of the nut relative to the head by any chance? |
yes. I presume you are using the ARP washers and flange nuts? yes. Did you mark the angle of the nut relative to the head by any chance? no.
Ingenieur
That all sounds good. I presume then that you have put some sort of sealing ring between the head and the cylinder flange. Is that correct?
It's an easy thing to mark the flange nut to detect loosing, but that is not very common. Happens though. |
Harold, it seems like multiple builders here and two that I’ve spoken to directly recommend against using ARP headstuds for the exact reason you are experiencing. No one seems to know exactly what it is about them that is the root cause of the issue, but it’s fireside knowledge now getting passed on. It sucks you’re dealing with this!
Before you swap them out for other studs, is there enough threads showing to try to double nut them? Spitballing here but would be an interesting test... check the easy to get to ones in 500 miles and see if it helped?
Ken 1986 930 2016 R1200RS |
Speedy Squirrel,
no sealing ring between the head the cylinder flange. gsxrken, I'll check to see how much thread there is. Worth a try at this point. What head studs are folks using?
Harold,
You could also try cleaning the lube off of the nut and (possibly?) stud, then torque to 38-40 ft-lbs. Rahl
1976 930 turbo Carrera, "Ubich". Mostly stock, lightly sweetened. She’s an angry schwierigkeit. She doesn’t want flowers, she just wants to dance! And when she does, she shakes her hips to the rythem of the road. Drive her like you hate her! |
Racer
We used 993 Turbo head studs for my race engine build. They seem to be "the" choice these days and they are, from what I am told by people that know, better than any other option out there.
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
Ingenieur
I think the nuts are loosening Gumba. I hope you will do the marking exercise to confirm this before taking everything apart.
ARP makes some really nice studs, very straight, and with rolled threads. They are used to designing head studs that are tightened to much higher torques than we can handle though. On top of everything else, they use that flanged nut. The bottom line is that the threads are super smooth, so they have low friction anyway, plus, they give you a lube that also lowers the friction. Finally, they give you a flanged nut that is also smooth. with black oxide coating for low friction. I agree with cleaning the oil off the threads, plus switching to a non-flanged nut. |
So the first suggestion is to:
clean off the threads switch to a non flanged nut torque to 38-40 lbs. any lube on the threads? Since the heads & cylinders have come loose, should I assume they will re-seal when I do the above procedure? Second choice is to disassemble and replace with 993 studs. The current part number is: 993-101-170-54, fully threaded dilivar stud. Can someone confirm this number.
Ingenieur
I agree. I won't use anything else. I think Porsche figured that rolling the entire stud closed up the grain boundary defects at the surface that were leading to inter granular corrosion, and ultimately, failure. Just guessing. They work though.
I believe one of the other suggestions is to scuff the washer surface so there is more friction between the nut and washer.
john |
Ingenieur
That is the correct part number.
https://www.pelicanparts.com/More_Info/99310117054.htm?pn=993-101-170-54-OEM They will probably reseal. There is no gasket or anything like that. Quote:
The 9 Store
All used parts sold as is. |
I'll try the first suggestion. This is in the bus, and I can actually get to all the head studs without dropping the motor. Sending the 7006 out for a few mods, so will be a few weeks before I can fire it up.
Thanks for all the suggestions.
Watching!!!
Just about ready to install ARP studs in my 3.0 build. Thinking that I will call ARP tomorrow, see what they say |
Puny Bird
Try Loctite sleeve fit 640 instead of lube.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
Try not, Do or Do not
Supertec has the solution.
https://www.pelicanparts.com/More_Info/SPTCHSK1.htm?pn=SPTC-HSK-1&bt=Y&fs=0&SVSVSI=911M
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
