-   -   rebuilding drbrian's 3.2l engine (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1079169-rebuilding-drbrians-3-2l-engine.html)
rcw911rsr 11-25-2020 05:13 PM
im not sure if any of you followed the auction where drbrian bought my 1988 carrera but he has asked me to rebuild the engine so i though that i would document everything here. i should have the engine out and disassembled this weekend to get the parts over to the machine shop monday morning.
http://forums.pelicanparts.com/uploa...1606353028.jpg
http://forums.pelicanparts.com/uploa...1606353116.jpg
http://forums.pelicanparts.com/uploa...1606353129.jpg
http://forums.pelicanparts.com/uploa...1606353135.jpg
http://forums.pelicanparts.com/uploa...1606353142.jpg
rcw911rsr 11-28-2020 06:43 PM
so the holidays slowed me down but i got it out today. i will take it apart tomorrow.
it is so much easier when everything is new and clean!
http://forums.pelicanparts.com/uploa...1606617636.jpg
http://forums.pelicanparts.com/uploa...1606617684.jpg
http://forums.pelicanparts.com/uploa...1606617781.jpg
Cairo94507 11-29-2020 06:33 AM
Excellent. Looking forward to watching this rebuild. Thanks for posting your work. :)
Brian T. Andrew 11-29-2020 10:11 AM
It has been a true pleasure working with Chris. He is a one man specialty shop producing fantastic restomods, and his enthusiasm is obvious. The 88 Carrera is just a hint of his creativity. And with the engine upgrades, she will see some great backroads use in California.
Check out his Lime Green RSR build on Instagram: Reimaginedcoachwerks!
rcw911rsr 11-30-2020 04:56 PM
thx for the kind words and confidence brian!
rcw911rsr 11-30-2020 05:00 PM
so i got the motor out and apart yesterday. after running some errands and getting a late start sunday i was exhausted and did not post yesterday. here are a couple of pics of taking the engine apart.
the shop is crowded right now because i had not planned on pulling this engine and have other cars in various stages of restoration, so excuse the mess!
http://forums.pelicanparts.com/uploa...1606784301.jpg
rcw911rsr 11-30-2020 05:02 PM
here is a pic of what the cylinders look like. i will post more after i run them through the heated sonic cleaner for a couple of hours.http://forums.pelicanparts.com/uploa...1606784538.jpg
rcw911rsr 11-30-2020 05:05 PM
i dropped the heads of today to get them disassembled asap so i can order the guides and any valves tomorrow.
i will drop the crank and case off wednesday when i get the parts for the valves job in. i hope to pick everything up friday or monday.
http://forums.pelicanparts.com/uploa...1606784681.jpg
rcw911rsr 11-30-2020 05:07 PM
and the CAT showed up today.
http://forums.pelicanparts.com/uploa...1606784804.jpg
Cairo94507 12-01-2020 07:14 AM
I must have missed it but that engine looks pretty clean and fresh as is. What was the reason for pulling it all apart to rebuild? Taking it to 3.4?
rcw911rsr 12-01-2020 10:27 AM
i was selling the car and redid the paint, interior, suspension and only resealed the engine because it ran so good. brian bought it and wanted the engine rebuilt so that everything was new.
you can search for the auction under my screen name on BaT to read what happened in greater detail.
rcw911rsr 12-01-2020 10:32 AM
so here is what we found as we split the case. everything looks great for 140k++ miles.
http://forums.pelicanparts.com/uploa...1606847441.jpg
rcw911rsr 12-01-2020 10:37 AM
i wanted to give a huge thank you to the man Steven Stomski! i bought, and paid for, every tool he makes and two of some of them like his billet crank stand, so know that this complement is real! i will never get tired of hearing case halves POP as they split with his case splitter!!!!
THANK YOU STEVEN! :cool:
http://forums.pelicanparts.com/uploa...1606847726.jpg
356911930 12-01-2020 12:45 PM
Is this build being done in California? If so, what machine shops are you using?
Thanks,
Rahl
rcw911rsr 12-01-2020 01:26 PM
getting done in dallas.
rcw911rsr 12-02-2020 10:35 PM
Received the gasket and bearing kits and valvetrain parts.
The case, crank, cams and rockers are in play now.
http://forums.pelicanparts.com/uploa...1606976978.jpg
http://forums.pelicanparts.com/uploa...1606977037.jpg
http://forums.pelicanparts.com/uploa...1606977085.jpg
http://forums.pelicanparts.com/uploa...1606977124.jpg
http://forums.pelicanparts.com/uploa...1606977166.jpg
http://forums.pelicanparts.com/uploa...1606977210.jpg
Cairo94507 12-04-2020 08:09 AM
Enjoying this thread. :)
ARCSinAK 12-06-2020 11:05 PM
As am I. Very close to starting the re-build on my 3.2 Euro.
rcw911rsr 12-08-2020 12:18 PM
so the cams, crank, oil pump and mahle p&c's are all on the way back to me. i hope to have them all by friday. the heads were done on saturday. we are getting close.
http://forums.pelicanparts.com/uploa...1607458555.jpg
rcw911rsr 01-04-2021 07:46 PM
so after waiting 3 weeks for the IMS thrust bearings to show up from germany and contending with the covid/holiday shipping for the crank, oil pump and cams we are finally gearing up to start Dr. Brian's engine assembly.
http://forums.pelicanparts.com/uploa...1609818323.JPG
