sorry the pic when zeroing the micrometer is a bit blurry...
http://forums.pelicanparts.com/uploa...1609888655.JPG http://forums.pelicanparts.com/uploa...1609888655.JPG http://forums.pelicanparts.com/uploa...1609888655.JPG http://forums.pelicanparts.com/uploa...1609888655.JPG |
we measure everything at the ideal temps to make sure it is as accurate as possible.
http://forums.pelicanparts.com/uploa...1609888813.JPG |
now the small end.
http://forums.pelicanparts.com/uploa...1609889143.JPG http://forums.pelicanparts.com/uploa...1609889143.JPG http://forums.pelicanparts.com/uploa...1609889143.JPG http://forums.pelicanparts.com/uploa...1609889143.JPG http://forums.pelicanparts.com/uploa...1609889143.JPG http://forums.pelicanparts.com/uploa...1609889143.JPG http://forums.pelicanparts.com/uploa...1609889143.JPG http://forums.pelicanparts.com/uploa...1609889143.JPG |
individual rod weights.
http://forums.pelicanparts.com/uploa...1609889316.JPG http://forums.pelicanparts.com/uploa...1609889316.JPG http://forums.pelicanparts.com/uploa...1609889316.JPG http://forums.pelicanparts.com/uploa...1609889316.JPG http://forums.pelicanparts.com/uploa...1609889316.JPG http://forums.pelicanparts.com/uploa...1609889316.JPG |
now the big end.
http://forums.pelicanparts.com/uploa...1609891527.JPG http://forums.pelicanparts.com/uploa...1609891527.JPG http://forums.pelicanparts.com/uploa...1609891527.JPG http://forums.pelicanparts.com/uploa...1609891527.JPG http://forums.pelicanparts.com/uploa...1609891527.JPG http://forums.pelicanparts.com/uploa...1609891527.JPG http://forums.pelicanparts.com/uploa...1609891527.JPG |
and the small end.
http://forums.pelicanparts.com/uploa...1609891689.JPG http://forums.pelicanparts.com/uploa...1609891689.JPG http://forums.pelicanparts.com/uploa...1609891689.JPG http://forums.pelicanparts.com/uploa...1609891689.JPG http://forums.pelicanparts.com/uploa...1609891689.JPG http://forums.pelicanparts.com/uploa...1609891689.JPG http://forums.pelicanparts.com/uploa...1609891689.JPG |
these are the weights straight out of the box from carrillo. i will massage them to close the gap but less than 1 gram difference is pretty awesome out of the box!
here are the piston weights. i also weigh all of the circlips and rings. they all weighed the same so not posting a pic of each one of those.
http://forums.pelicanparts.com/uploa...1609966265.JPG http://forums.pelicanparts.com/uploa...1609966265.JPG http://forums.pelicanparts.com/uploa...1609966265.JPG http://forums.pelicanparts.com/uploa...1609966265.JPG http://forums.pelicanparts.com/uploa...1609966265.JPG http://forums.pelicanparts.com/uploa...1609966265.JPG http://forums.pelicanparts.com/uploa...1609966265.JPG http://forums.pelicanparts.com/uploa...1609966265.JPG |
here are the wrist pins.
http://forums.pelicanparts.com/uploa...1609966606.JPG http://forums.pelicanparts.com/uploa...1609966606.JPG http://forums.pelicanparts.com/uploa...1609966606.JPG http://forums.pelicanparts.com/uploa...1609966606.JPG http://forums.pelicanparts.com/uploa...1609966606.JPG http://forums.pelicanparts.com/uploa...1609966606.JPG |
now that everything has been weighed we can start to balance each assembly by mixing and matching individual parts based on weight and then removed weight only from the parts that need it.
http://forums.pelicanparts.com/uploa...1609967038.JPG |
here are the rod small ends.
http://forums.pelicanparts.com/uploa...1609967155.JPG http://forums.pelicanparts.com/uploa...1609967155.JPG http://forums.pelicanparts.com/uploa...1609967155.JPG http://forums.pelicanparts.com/uploa...1609967155.JPG http://forums.pelicanparts.com/uploa...1609967155.JPG http://forums.pelicanparts.com/uploa...1609967155.JPG |
rod big ends.
http://forums.pelicanparts.com/uploa...1609967501.JPG http://forums.pelicanparts.com/uploa...1609967501.JPG http://forums.pelicanparts.com/uploa...1609967501.JPG http://forums.pelicanparts.com/uploa...1609967501.JPG http://forums.pelicanparts.com/uploa...1609967501.JPG http://forums.pelicanparts.com/uploa...1609967501.JPG |
overall final rod weights. i call it done with 2-3 tenths of a gram difference as there is inevitably more or less oil on each part in the eng. imho zero zero is eyewash and like a peeky dyno sheet, it is something to brag about but not very practical in real life.
in the end you will see i get everything where it needs to be. http://forums.pelicanparts.com/uploa...1609967797.JPG http://forums.pelicanparts.com/uploa...1609967797.JPG http://forums.pelicanparts.com/uploa...1609967797.JPG http://forums.pelicanparts.com/uploa...1609967797.JPG http://forums.pelicanparts.com/uploa...1609967797.JPG http://forums.pelicanparts.com/uploa...1609967797.JPG |
here is the final weight and orientation for each assembly.
http://forums.pelicanparts.com/uploa...1609968007.JPG |
i had the crank, FW, PP and front pulley all balanced separately down to 0.3 grams so this motor should run smoothly and rev freely!
Sometimes tables and charts work better than photos.....this is one of those times.
i actually have always loved using excel so just let me know what you are looking for. |
we got the perimeter bolts in and im working on clearencing the oil pump and nearest carrillo rods to make sure there is no chance of contact.
http://forums.pelicanparts.com/uploa...1610050645.JPG http://forums.pelicanparts.com/uploa...1610050645.JPG |
| All times are GMT -8. The time now is 01:30 PM. |
