here are a couple pic of the case work.
http://forums.pelicanparts.com/uploa...1609818484.JPG http://forums.pelicanparts.com/uploa...1609818525.JPG |
and a few of the crank work. the crank was std/std after 140k. :cool:
http://forums.pelicanparts.com/uploa...1609818623.JPG http://forums.pelicanparts.com/uploa...1609818623.JPG http://forums.pelicanparts.com/uploa...1609818623.JPG |
calling it a night. we got the case halves together and checked all of the case bores. i do not trust gauges, therefore i use not only the goto sunnen bore gauge with setting fixture; but i use my mitutoyo holtest inside micrometers. everything measured in spec.
we torqued the though case bolts. http://forums.pelicanparts.com/uploa...1609829670.JPG http://forums.pelicanparts.com/uploa...1609829670.JPG if you are not familiar with how a bore gauge works, but at the rock over point is when you get the actual dimension therefore its hard to get the rock over point on camera. so the pics of the bore gauge are arbitrary. http://forums.pelicanparts.com/uploa...1609829217.JPG http://forums.pelicanparts.com/uploa...1609829217.JPG http://forums.pelicanparts.com/uploa...1609829217.JPG http://forums.pelicanparts.com/uploa...1609829217.JPG the bore gauge is set with the setting fixture. http://forums.pelicanparts.com/uploa...1609829771.JPG http://forums.pelicanparts.com/uploa...1609829771.JPG |
my favorite is to use a mitutoyo inside micrometer! i try to keep the room temp and humidity to the temp/hum that mitutoyo used when they calibrated these tools.
http://forums.pelicanparts.com/uploa...1609829944.JPG first i zero them. http://forums.pelicanparts.com/uploa...1609829987.JPG http://forums.pelicanparts.com/uploa...1609829987.JPG http://forums.pelicanparts.com/uploa...1609829987.JPG http://forums.pelicanparts.com/uploa...1609829987.JPG http://forums.pelicanparts.com/uploa...1609829987.JPG |
a few more...
http://forums.pelicanparts.com/uploa...1609830395.JPG http://forums.pelicanparts.com/uploa...1609830395.JPG http://forums.pelicanparts.com/uploa...1609830395.JPG http://forums.pelicanparts.com/uploa...1609830395.JPG http://forums.pelicanparts.com/uploa...1609830395.JPG http://forums.pelicanparts.com/uploa...1609830395.JPG |
The organization is extremely satisfying!
Nice work.
Who did you use for plating ? So few good platers in the DFW area. Who machined the heads? TIA ! |
i get the heads done with a retired machinist that works by appointment only for long time clients. he also gets my hardware plated by one of his venders.
i was trained by the legend John Bray, owner of evospec in AZ, many moons ago and he sets a high standard at his shop. you have to spend one solid day minimum cleaning all of the parts one by one, over and over and over...
a few pics of old versus new parts for dr. brian.
http://forums.pelicanparts.com/uploa...1609876233.JPG http://forums.pelicanparts.com/uploa...1609876233.JPG http://forums.pelicanparts.com/uploa...1609876233.JPG http://forums.pelicanparts.com/uploa...1609876233.JPG http://forums.pelicanparts.com/uploa...1609876233.JPG http://forums.pelicanparts.com/uploa...1609876233.JPG |
here we measure the crank with outside micrometers. first we zero the micrometer then start with the main journals.
ADD 50MM TO EACH MEASURMENT http://forums.pelicanparts.com/uploa...1609880044.JPG http://forums.pelicanparts.com/uploa...1609880044.JPG http://forums.pelicanparts.com/uploa...1609880044.JPG http://forums.pelicanparts.com/uploa...1609880044.JPG http://forums.pelicanparts.com/uploa...1609880044.JPG http://forums.pelicanparts.com/uploa...1609880044.JPG http://forums.pelicanparts.com/uploa...1609880044.JPG http://forums.pelicanparts.com/uploa...1609880044.JPG |
here are the rod journals.
ADD 50 MM TO EACH MEASUREMENT http://forums.pelicanparts.com/uploa...1609880455.JPG http://forums.pelicanparts.com/uploa...1609880455.JPG http://forums.pelicanparts.com/uploa...1609880455.JPG http://forums.pelicanparts.com/uploa...1609880455.JPG http://forums.pelicanparts.com/uploa...1609880455.JPG http://forums.pelicanparts.com/uploa...1609880455.JPG |
ADD 75MM TO EACH MEASUREMENT
http://forums.pelicanparts.com/uploa...1609880860.JPG http://forums.pelicanparts.com/uploa...1609880860.JPG |
Thanks |
Subscribed! Dr. Brian, your 911 is bad ass! Great work rcw911rsr! I'm looking forward to this build.
remeasuring with mechanical mics to double check.
http://forums.pelicanparts.com/uploa...1609888217.JPG http://forums.pelicanparts.com/uploa...1609888217.JPG http://forums.pelicanparts.com/uploa...1609888217.JPG http://forums.pelicanparts.com/uploa...1609888217.JPG http://forums.pelicanparts.com/uploa...1609888217.JPG http://forums.pelicanparts.com/uploa...1609888217.JPG http://forums.pelicanparts.com/uploa...1609888217.JPG http://forums.pelicanparts.com/uploa...1609888217.JPG |
rod journals
http://forums.pelicanparts.com/uploa...1609888357.JPG http://forums.pelicanparts.com/uploa...1609888357.JPG http://forums.pelicanparts.com/uploa...1609888357.JPG http://forums.pelicanparts.com/uploa...1609888357.JPG http://forums.pelicanparts.com/uploa...1609888357.JPG http://forums.pelicanparts.com/uploa...1609888357.JPG |
| All times are GMT -8. The time now is 01:31 PM. |
