ADDvanced's Avatar
New Fuel Injector Inserts (77 CIS), do I have to stake them into the runners?
I just put them in with a 10mm socket and an extension and some thwacking. They seem like they aren't going ANYWHERE. Do I definitely have to stake them or ?
IG@ADDvanced
Youtube@ADDvanced
www.gruvdesign.com
Old 12-02-2020, 05:10 PM
Steve F's Avatar
Thumbs up
I used a clicker center punch, easy, peasy
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate
1967 912-1985 Toyota FJ60 Landcrusier
1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4
1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag
1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS
Old 12-03-2020, 05:46 AM
ADDvanced's Avatar
Okay, I will do that.
IG@ADDvanced
Youtube@ADDvanced
www.gruvdesign.com
Old 12-03-2020, 07:33 AM
Registered Minimalist
75 911s's Avatar
I didn't stake mine. No issues for 9k miles. Just removed the CIS and nothing had pulled. I'd probably stake them now though in retrospect.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 12-04-2020, 06:50 AM
Walt Fricke's Avatar
Since sometimes these hard plastic liners come out when all you want to do is pull the injector, it makes sense to stake, which isn't hard. You wouldn't want to glue them, so to speak, because they can get brittle and bits break off when pulling injectors, so they need to be pretty easy to remove as needed. The fat injector O ring exerts a lot more grip on the liner than the thin seal for the liner does to the manifold, so I'd expect if you pulled an unstaked injector the liner would come with it. Nothing someone prepared for this can't deal with easily, especially if you expect it. I try always to have a couple of new liners and their seals handy any time I pull an injector, just in case.
Unlike piston oil squirters (also staked), there is only the reaction to the constant flow of fuel to try to push them out on their own, and I guess that isn't at all like EFI (where there are stout structures holding those injectors in place). Interesting that you replaced the inserts but didn't stake, and all has been well. Good to know.
Old 12-04-2020, 08:37 PM
Do you have to? No
LOL, staking is another Model T technology that lived on at Porsche, much like wood floorboards, cardboard body parts, and tin wrapped exhaust passing as a heater.
Old 12-06-2020, 08:04 AM
