3D model/render work on the 2.2T motor I'm building
Originally I had all of this sprinkled throughout my engine build thread. Since it's somewhat of a budget build I get time to get up close and personal with each of these parts as I'm cleaning and inspecting and saving for parts and machine work.
You'll notice that in a lot of these the color/finish of the individual parts isn't exact. Each time I add to the model I make a new render file, and then I reassign colors to each part all over again. Because of this, I don't spend a ton of time honing the colors down. Once it's complete I'll get everything so that they look right but for now it's just WIP eye candy.
I don't update this thread with every new part I make, to see everything in the most up-to-date fashion visit my Instagram www.instagram.com/autoillustrated/
Hope you all enjoy!
Gotta start somewhere.
Old 09-22-2017, 09:39 PM
started working on the cam housings
Old 09-22-2017, 09:40 PM
cam covers coming along nicely
Old 09-22-2017, 09:42 PM
Had an open evening, so more progress, adding parts one by one.
Old 09-22-2017, 09:43 PM
Beautiful !
Old 09-23-2017, 03:19 AM
Tom '74 911's Avatar
I spend most of my work day using ArchiCAD to design & 3D model buildings... what you are doing is a whole 'nother deal. Seriously impressive CAD/3D modeling skills... I dig it.
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 09-23-2017, 07:31 AM
Really great work. Are you scanning the parts?
Old 09-23-2017, 09:08 AM
No shortcuts (scanning) I measure and create each feature.
Old 09-23-2017, 09:38 AM
3Ddesigns911's Avatar
Nice work man.How far are you going to take it? BTW what engine is this exactly?
Old 09-23-2017, 10:34 AM
Thanks! I'll be doing the full carburated engine. It's a 911/07 from a '71 911T
I might do a quick and dirty trans, but just so I can put it all in a 914/6 GT 3D model I have.
Old 09-23-2017, 10:52 AM
Wow. Lots of work there.
I can appreciate what you are doing because I started my case project by scanning a case at 50 microns and then modifying it to create the model for our casting.
Nice job.
Old 09-23-2017, 11:08 AM
I do wish I could scan the case, I've been dreading that part.
Old 09-23-2017, 11:26 AM
There has to be some scans or other 3D models that you can start with out there. It'd be pretty hard to get it accurately just by measuring.
Old 09-23-2017, 12:18 PM
My case model cost me $100,000 to give you an idea. It wasn't just scanning, it was the reverse engineering and the measurements, which are still ongoing. The scan and the point cloud just gave us a basic shape.
However, my model needed to be good enough to build off of, it is not a simple exercise in art. Dimensionally, it is perfect. But it was just a starting point for us.
I think you'll be able to simulate the exterior of the case pretty well based on your work you showed here. It doesn't need to be perfectly accurate....no one will ever be able to tell.
Old 09-23-2017, 12:41 PM
Nothing out there for the case, realistically I would prefer to do it myself so that I can ensure the case model is done to the same standard as the rest of it. Plus, native Creo models are far superior to mesh, 3dsMax, or stl model files.
I know it doesn't need to be 100% correct, I'm not building casts for any of this. It is likely that I'll be 3d printing a scale version.
Old 09-23-2017, 01:21 PM
What I meant was if you had something to start with as a "template" then you could create your own model based on that while verifying dimensions.
Old 09-23-2017, 02:10 PM
Kartoffelkopf
Spenny_b's Avatar
They. Are. Stunning!
Seriously impressed, not only the quality of the images but also your patience. I wish I had an attention span longer than
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html
On Instagram (along with other stuff) as @spenny_.b #spennybengineproject
Old 09-23-2017, 04:30 PM
Thank you!
More progress.
Old 09-24-2017, 08:15 AM
Amazing. I can somewhat use Solidworks - how is the software you are using different? Is it supposed to be for the same kinds of tasks???
Old 09-24-2017, 09:53 AM
Yes, Creo is previously known as Pro/Engineer. It is an engineering modeling/drafting software. It does the same tasks as Solidworks. I do use Solidworks as well, usually only when one of our vendors sends us native SW files though, I prefer Creo.
Which is better is a highly debated topic with "fan-boys" on both sides of the fence. Solidworks is easier to pick up for beginners, but in my opinion Creo has more functionality. The same geometry can be created with either program, the methods are just different.
The models are created in Creo. These models could be machined, 3D printed, or with some redesign they could be plastic injection molded. Currently I've just been exporting the models to another software Keyshot which is just a rendering software. It takes the models in and I can assign colors, finishes, etc and render fancy images in high resolution.
Old 09-24-2017, 10:11 AM
