ARP ? Rod bolts
New rod bolts. ARP or our hosts ones.
A 67 S 911 used as a runabout Lyndon |
What is the cost difference between the ARP kit and the 12 bolts and 12 nuts? What is your intended use of the motor/car? How much do want to risk?? The difference appears to be about 37 bucks. You won't regret going with the ARP.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
It's a 914 ...
I'd go with ARP for similar $$, hands down.
Note that due to the higher torque value of the ARP bolts, you should have the rod big ends checked with the ARP's and resized if needed. |
Try not, Do or Do not
We use ARP bolts whenever possible. We even devised a simple machining process that allows us to use 2.7/3.0 ARP bolts in 2.2 rods. ARP never made a bolt for that application so a little ingenuity was required. We even use the ARP/Wrightwood bolts to replace the factory bolts in the Pankl titanium GT3 rods.
Nothing, except Carrillo rods leaves our shop without ARP rod bolts. A side note about Carrillo bolts: although Carr bolts are infinitely stronger, WMC bolts are still a stellar choice for most Porsche flat six applications. Sometimes "more" is just "more" hype.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Agree 100% Henry. Just assembled this 930 shortblock this morining with Carrillo rods and WMC bolts. Even the water cooled Porsche motors we build get Carrillo rods with their WMC bolts.
![]() Cheers
Racer
My engine architect, William Knight, must be stupid and subject to hype. After all, he uses 2 MSD ignitions with 2 coils, he uses 993 Twin Turbo head studs, and he prefers CARR fasteners for his higher performance builds. What a tool I am for listening to his advice. [/SARCASM]
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
Ok I'm going with ARP 204-6003
To my surprise they vary from 160 to 280 from two well known suppliers in the USA. Am I missing something here ?? 1967 911S Also can I confirm this 204-2802 is the correct flywheel Bolt kit ??? Lyndon |
Scott,
You have clearly done lots of research. But I have to ask, what is your point with the post above? If William prefers the CARR bolt, he can post and say so? CP/Carrillo has good info on their site about the properties of each fastener. Cheers
Here's a little bit of science for those who think for themselves sans the need for the “cool kids” approval. Most engine builders here agree that ARP rod bolts are a great upgrade for factory rods.
What I call that is “hype”. Quote:
Of course for some inexperienced drivers, over-revs are a common occurrence so the best bolt might be the better choice. BTW: My reference to "cool kids" is simply a metaphor for hero worship. When it comes to technical issues, the data someone offers and the experience they bring to the specific discussion is far more important than "who" that person is.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 03-08-2021 at 07:05 AM.. |
Jeff, you probably know this but I am posting to help people unlike you or Henry, I actually use all 4 bolts, The ARP, ARP 2000, WMC, and CARR.. It depends on the application.
The deal with using CARR bolts over and over is something I don't agree with. I may use the three times, WMC once, ARP once, ARP 2000 maybe twice.. The factors that dertermine the bolts used, Pauter uses both ARP and ARP 2000, CP uses WMC and CARR. I like the WMC bolt in most applications as it saves about $350 but the main difference in the bolts is the clamping force. It is directly proportionate to the tensile strength of the bolt. on a 70 mm stroke is is much less critical than an 80 mm stroke, the piston weight is another big component along with RPM obviously. Race motors where we change rod bearing's and rings before a rebuild often benefit from the CARR bolt.. Most DE level street hot rods do not need premium bolts.. One more tip for nonprofessionals the longer stroke means the piston is traveling faster at the same RPM. secondly in my opinion the number one reason new builds fail prematurely is people changing there stock rod bolts to ARP rod bolts without correcting the roundness of the rod.. Hope this helps some new people keeping the air-cooled world alive as there are definitely not enough qualified people to do this anymore. |
If the bolt is tightened using the stretch method and the unstressed bolt measures within spec, why would it be necessary to change?
Just a fine line between yield point and Elastic region. Also I have less comfort on too many uses on high RPM high Stress motors that are very expensive to rebuild.
abit off center
So sizing the rod doesn't count as "one" use?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
If you are changing to ARP bolts for example in a stock a rod, it counts for 1 stretch cycle.
Further, if someone is rebuilding a motor without resizing the big end, regardless of their bolt choice, they deserve what ever happens... ![]() Cheers
I've decided to buy a set of pauter rods
They come with bolts and I don't need to resize my S rods. I will know they are perfect and it's the last time I will need to look at my bottom end. PS engine is running well but it's getting a birthday soon. Lyndon |
Interesting choice: When engineers and engine builders get together to discuss rod designs the conversation centers around strength vs weight, materials and grain structures. They explore the benefits of H beam vs I beam vs A beam. They never seem to include the X beam design. Why is that?
I get a kick out of your reference to "High stress motors" when the bolts manufacturers are quoting numbers like 10,000 rpm and 1250 to 1500 hp.
Jeff one of the biggest causes of failure are guys upgrading to an ARP bolt without correcting the big end. They get there rods done then change bolts, cars usually live 70 to 100 miles. I have seen it about 10 times. other issue is cam sprockets.. I hope we can all help keep people from having issues..
Sprockets ??
Big ends ? Could you elaborate on theses. I don't want to get it wrong. Lyndon |
