barometric cell MFI pump
Hi,
In the progress collecting parts to build 2.45 l engine(Henry Schmidt) I keep the option open to have a MFI instead of Webers. So did send my 2.2E pump to Germany for a check. One of the outcomes was the barometric cell was not functioning.
As I planned (looking forward)to work, adjust and tune the MFI pump myself based on all the great info on this Forum I need to find this Barometric cell.
So if anybody knows where I can buy one, please let me know!
Thanks,
Bart
Old 04-22-2021, 03:53 AM
Try not, Do or Do not
Henry Schmidt's Avatar
We have a few. I just need to figure out how to test them.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 04-22-2021, 02:25 PM
Hi Henry!
Just sent you a PM.
Thanks,
Bart
Old 04-22-2021, 11:55 PM
Direct email is the best way to get my attention.
And because I get 200+ email a day, that method can be challenging as well.
Henry Schmidt
Ph: 760-728-3062
Old 04-23-2021, 10:14 AM
Hi Henry,
Again, thanks for responding.
I really don't like you to go through all effort of testing.....
(Maybe first question is what you asking for them.)
As depending on that I can take the 'gamble' that it does work and do the testing here in the Lowllands!?
Cheers,
Bart
p.s. Would this work....put the cell in a bigger seal bag with air. Close the bag and put a load(pressure with your hands) on the bag.....It does not need a lot. I guess the cell will work 2 way (higher and lower pressure)
To achieve the lower air pressure one will need a bit more effort I guess . I also believe if the pressurizing works the cell is ok, right!? not sure if movement is visible by the eye...
Old 04-24-2021, 01:32 PM
