dgmark's Avatar
Pilot bushing for 3.3 turbo with GT3 Crankshaft
I am stuck on what Pilot bearing to use in a 3.3 turbo with a gt3 crankshaft and stock turbo clutch. As the gt3 crankshaft does not haver holes to bolt the stock bushing in place I need an alternative.
30 Year ASE Master Certified Technician
1986 911
Old 05-17-2021, 03:14 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Flywheel mounted pilot bearing.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-17-2021, 04:30 PM
dgmark's Avatar
So I need to use a 77 -79 flywheel?
1986 911
Old 05-17-2021, 04:39 PM
It depends on the transmission you're running.
You can also drill the GT3 crank for bearing mounting.
Henry Schmidt
Ph: 760-728-3062
Old 05-17-2021, 04:51 PM
