Pilot bushing for 3.3 turbo with GT3 Crankshaft
I am stuck on what Pilot bearing to use in a 3.3 turbo with a gt3 crankshaft and stock turbo clutch. As the gt3 crankshaft does not haver holes to bolt the stock bushing in place I need an alternative.
30 Year ASE Master Certified Technician 1986 911 |
Try not, Do or Do not
Flywheel mounted pilot bearing.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
So I need to use a 77 -79 flywheel?
It depends on the transmission you're running.
You can also drill the GT3 crank for bearing mounting.
