Red face 2.7 CIS rebuild
So I had to strip down my engine and it is not looking good.
Attached some pictures of what was found so far.
Funny (or tragic) thing is that the car went through a top end job 4 years ago.
Old 04-28-2021, 12:55 PM
Tomorrow we are going into the Crankshaft...fear of the Dark! fear of the Dark!
Old 04-28-2021, 12:59 PM
Old 04-28-2021, 01:00 PM
Has anyone here done the upgrades mentioned on the Wayne Dempsey article?
I'm referring to this article
https://www.pelicanparts.com/techarticles/911_engine_rebuild/911_engine_rebuild2.htm
Thanks for your comments and contributions
Old 04-30-2021, 02:21 AM
Have you been inside the crank case yet?
I too, was thinking about the 964 cams and the piston upgrade. I wonder if you can do the cams first and then the pistons at a later date?
I already have SSI heat exchangers on it.
Interested to see what you find.
76 911S
Land Rover 110 Defender
Old 05-13-2021, 04:02 AM
Hi yes, we open the crank case and thank god is all good there. Basically this was a poorly done valve job that turned ugly. Rocker arms not properly adjusted so most likely they eat up the cams.
Spoke to a very reputable 911 engine builder and he mentioned that the Wayne Dempsey article refers to a 3.0 engine and not a 2.7, different beasts. Suggested me to stick with the original cams but time them as the 74 Carrera (the 75s were timed different due to emission controls).
Old 05-18-2021, 02:48 PM
That's good news that inside is OK.
76 911S
Old 05-18-2021, 05:47 PM
Alan L's Avatar
Check the cam spray bars - you probably already have.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 05-19-2021, 01:00 AM
