Author of "101 Projects"
Wayne 962's Avatar
Pelican Parts So what do you think of this engine?
Okay, I'm in need of an engine for my 914-6. The original engine that was in that car is the 2.7L engine that was featured in the engine book. This engine is currently sitting in our showroom. Hence I need another one for my sixer.
Here's what I'm thinking:
- Euro Carrera 3.0L case
- 2.7 liter crank/rods
- 3.0 cylinders replated with Nikasil
- JE 3.0 high compression pistons or 100mm 3.2 pistons
- Either 2.7 or some 3.2 933 Turbo airplane heads I have.
- TEC-3 engien management system with twin-plug capability.
This would be a short-stroke 3.2, high compression engine with the small flywheel end that would plug right into the 901.
Any thoughts?
-Wayne
Old 05-03-2003, 11:31 PM
Navin Johnson
TimT's Avatar
Thumbs up
Wayne that is going to be a "hold on to your hat" fun set up!!
As a comparison, I have a 914/6 with a 3.2
10.5:1 JE's
Web Cam 20/21
Weber 46's
Tall manifolds
This is coupled to a short geared 901 box (AFMSX), This uses a '70/71 pull flywheel (this uses a custom pull type shift fork set up).
You will need to get a heavy duty clutch and pressure plate, (my stock clutch slipped under load on the 3rd/4th/5th shift)
I use the centerforce 915 RSR clutch now.
Youll have a blast in a 914 with the power the engine your building will make..What size rubber do you have on the car?
'69 911 GT-5
'75 914 GT-3
and others
Old 05-04-2003, 07:58 AM
Wayne 962's Avatar
I will have nines in the back and sevens or eights in the front. I have stock 5 1/2s on there right now. The engine is first for the car - suspension and flares is next. This car hasn't really run since I founded Pelican more than five years ago. Needless to say, I'm getting antsy...
-Wayne
Old 05-04-2003, 10:36 AM
That engine would probably make that car a kick to drive. Especially with a set of cams that would make power to about 7K
Chuck
90 C2
78 911SC
79 911SC
Old 05-04-2003, 03:41 PM
Perfect
Chuck
90 C2
78 911SC
79 911SC
Old 05-04-2003, 05:28 PM
