Tall or short manifold for a 3.2
Hi!
I am building a 3.2 engine with a 46 Weber. The engine is stock, only the cam is DC21 I have source for "short" and a "tall" PMO manifold set. The intake port is 41mm, The short set is 35mm diameter on the intake side and the tall set is 41mm. Which is better to install? I am installing this engine into a SWB car, is the tall set might be too tall?
tall. for midrange torque. I think
80SC (ex California) |
Chain fence eating turbo
In this case, you definitely want the 41mm as the ports are 41.5mm IIRC. Using a 35mm port will choke the heads for sure.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
Jeff Day
![]() I can supply 98mm tall manifolds to suit 40 and 46 mm applications with up to 41mm ports. Also available with fuel injection bosses for efi, with a 100 mm tall throttle body, so the height is no taller than a conventional carb on a short manifold. A standard air filter still fits as well
Remember, the heads on 3.2, the intakes are shorter at least by the thickness of the insulator and one intake gasket
I’d go tall… Bruce |
Just checked the space between the heads and the engine roof.
Seems like the "tall" intake can hardly fit with the K&H filter house |
Jeff Day
That’s why I’ve made Weber pattern high butterfly throttle bodies, which a MFI inspired linkage that are only 100mm
Racer
Go tall....
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
Jeff Day
![]() Pictured is the prototypes, production will be better finished, and linkages zinc plated Last edited by Westbound; 08-15-2021 at 02:46 AM.. |
