Tall or short manifold for a 3.2
Hi!
I am building a 3.2 engine with a 46 Weber. The engine is stock, only the cam is DC21 I have source for "short" and a "tall" PMO manifold set. The intake port is 41mm, The short set is 35mm diameter on the intake side and the tall set is 41mm. Which is better to install? I am installing this engine into a SWB car, is the tall set might be too tall? ![]() |
tall. for midrange torque. I think
80SC (ex California) |
Chain fence eating turbo
In this case, you definitely want the 41mm as the ports are 41.5mm IIRC. Using a 35mm port will choke the heads for sure.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR P & C's, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, depending on mood ![]() |
Jeff Day
![]() I can supply 98mm tall manifolds to suit 40 and 46 mm applications with up to 41mm ports. Also available with fuel injection bosses for efi, with a 100 mm tall throttle body, so the height is no taller than a conventional carb on a short manifold. A standard air filter still fits as well ![]() |
Remember, the heads on 3.2, the intakes are shorter at least by the thickness of the insulator and one intake gasket
I’d go tall… Bruce |
Just checked the space between the heads and the engine roof.
Seems like the "tall" intake can hardly fit with the K&H filter house |
Jeff Day
That’s why I’ve made Weber pattern high butterfly throttle bodies, which a MFI inspired linkage that are only 100mm
Racer
Go tall....
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
Jeff Day
![]() Pictured is the prototypes, production will be better finished, and linkages zinc plated Last edited by Westbound; 08-15-2021 at 01:46 AM.. |
Thread Tools | |
Rate This Thread | |
