Tall or short manifold for a 3.2
Hi!
I am building a 3.2 engine with a 46 Weber.
The engine is stock, only the cam is DC21
I have source for "short" and a "tall" PMO manifold set.
The intake port is 41mm,
The short set is 35mm diameter on the intake side and the tall set is 41mm.
Which is better to install?
I am installing this engine into a SWB car, is the tall set might be too tall?
Old 08-06-2021, 11:40 PM
tall. for midrange torque. I think
80SC (ex California)
Old 08-08-2021, 03:59 AM
Chain fence eating turbo
In this case, you definitely want the 41mm as the ports are 41.5mm IIRC. Using a 35mm port will choke the heads for sure.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 08-08-2021, 10:33 PM
Jeff Day
I can supply 98mm tall manifolds to suit 40 and 46 mm applications with up to 41mm ports.
Also available with fuel injection bosses for efi, with a 100 mm tall throttle body, so the height is no taller than a conventional carb on a short manifold.
A standard air filter still fits as well
Old 08-08-2021, 11:30 PM
Remember, the heads on 3.2, the intakes are shorter at least by the thickness of the insulator and one intake gasket
I’d go tall…
Bruce
Old 08-11-2021, 04:25 PM
Just checked the space between the heads and the engine roof.
Seems like the "tall" intake can hardly fit with the K&H filter house
Old 08-12-2021, 10:17 AM
Jeff Day
That’s why I’ve made Weber pattern high butterfly throttle bodies, which a MFI inspired linkage that are only 100mm
Old 08-15-2021, 02:32 AM
Racer
winders's Avatar
Go tall....
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 08-15-2021, 02:42 AM
Jeff Day
Pictured is the prototypes, production will be better finished, and linkages zinc plated
Old 08-15-2021, 02:43 AM
