Another case sealant question
Ive pulled my early case apart. It looks like the factory had no sealer on what I call the main caps.
It was only on the outer perimeter.
Wayne's book show it everywhere. Is this for uniformity on the case halves or ??
Thanks lyndon
Old 09-07-2021, 04:49 PM
Hi Lyndon
my understanding is that the factory did not apply sealant in that area.
However many reputable builders do apply it and others do not. I don't know which method is best.
One day, I will do a test to measure my oil clearance both with, and without sealant on the bearing webs, to see if it makes an appreciable difference.
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 09-08-2021, 03:19 AM
The factory specifically states to NOT install sealer on the main webbing. Other reputable engine builders do though. To each their own.
Personally, I am of the opinion that anything between the two surfaces affects the bearing clearances and should be avoided. The case halves didn't have sealer on them when the align boring tasks were completed, so adding anything will change your measurements.
Old 09-08-2021, 04:47 AM
It's a 914 ...
stownsen914's Avatar
I've wondered how effective sealant on the webs would be, since we know that they do fret/move. I'd think the sealant would be compromised by the movement.
Old 09-08-2021, 06:00 AM
Exactly!!!!
If this is hard to understand, then think this way. What are you actually sealing from leaking?
Old 09-08-2021, 06:18 AM
That's my thinking. But I'm no expert. There must be some reasoning. I'm following the book under the premise it's correct. Or just this bit is not correct.
I'm inclined to follow Porsche I think.
Lyndon
Old 09-08-2021, 06:29 AM
Easily Confused
dtxscott's Avatar
Originally Posted by Neil Harvey View Post
Exactly!!!!
Prezactly!
Scott C.
'08 Cayenne GTS 6MT : '89 Targa GP White/Black - "Oliver's Car" : '11 Mitsu Evo X : '08 Lexus IS350 F-Sport : '01 Toyota Sequoia : 1998 Yamaha V-max : 1979 BMW R65
Old 09-08-2021, 06:35 AM
Lyndon
Don't over think it!! It will make your head hurt.
Old 09-08-2021, 06:40 AM
