abit off center
cgarr's Avatar
72 injected head insert
After 20 years this is a first, are these injector inserts removal, they look screwed in but not sure. And are they available?
Craig
Old 01-16-2025, 04:54 AM
abit off center
cgarr's Avatar
______________________
Craig
G2Performance
Old 01-16-2025, 05:02 AM
Try not, Do or Do not
Henry Schmidt's Avatar
The aluminum sleeve is not available. The rubber seals/was available.
The aluminum sleeve is pressed in. Over the years we have thrown those heads away when the injector was not being used in a new build. Because good heads are becoming harder to find, now we remove the sleeve and weld or insert the whole. Welding when carbs are installed and inserted when MFI is being retro fitted.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 01-16-2025, 06:06 AM
Is it possible to tap these out for injectors directly into the heads?
Old 01-16-2025, 07:09 PM
The only injector you would want to install directly in the head is an MFI injector. The existing hole is larger than the MFI injector. That is why, in my response I states that an insert is required. What we've done in the past is use an oversized (big) Timesert but we have also made press in inserts that are tapped to suit the MFI injector.
Henry Schmidt
Ph: 760-728-3062
Old 01-17-2025, 06:53 AM
abit off center
cgarr's Avatar
Since the inserts are not available and we wanted to keep things stock, the rubber bushings are still available so I fired up the old Hardinge cnc lathe and made a set of six. Happy these are finally done, ship them out!!
Craig
G2Performance
Old 01-25-2025, 12:26 PM
Nice job Craig
Old 01-25-2025, 12:59 PM
prschmn's Avatar
You've got an Omniturn? I'm jealous! Nice work.
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
Radical Prosport-irritates the GT3 guys
40 years of rebuilding services
Old 01-26-2025, 04:44 AM
abit off center
cgarr's Avatar
It’s a Hardinge GT-27SP Turning Center
Craig
G2Performance
Old 01-26-2025, 07:35 AM
