JoeMag's Avatar
3.8 pistons -- what's a good weight?
What would be considered a good light weight 102.0mm pistons 12.5 cr?
Considering that for my Mahle 3.8 cyl's (I have the mahle 11.4cr 489g ones now).
Old 11-07-2021, 04:06 PM
Bill Verburg's Avatar
Lightest I've ever seen are the 9M @450g
Bill Verburg
Old 11-12-2021, 04:02 PM
Racer
winders's Avatar
Check with CP.....
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 11-12-2021, 04:08 PM
JoeMag's Avatar
Thanks Bill... I have since found out EBS has 454g piston.
Old 11-13-2021, 04:19 AM
Jeff Alton's Avatar
A good weight is whatever the engineers at the various manufactures have ENGINEERED their pistons at. Like Scott said, check with CP (who we have build our pistons), and perhaps check with JE and Mahle as well.
Then ask, what are you trying to achieve? What are the rest of the engine build specs? What are you trying to accomplish? A super light piston is awesome right up until the pin boss separates from the rest of the piston....
Cheers
www.turn3autosport.com
Old 11-14-2021, 07:48 PM
JoeMag's Avatar
Thanks Jeff... Agree with you. Several engine builders noted the Mahle 11.4 102mm as race piston's were "heavy" piston's, so was just checking.
Old 11-18-2021, 09:26 AM
Jeff Alton's Avatar
Joemag, if you have one, send me the weight via email, I can compare to some other pistons we have around...
Old 11-19-2021, 08:44 PM
JoeMag's Avatar
Sent off to Jeff, however, for the knowledge of the forum, here's weight of spare piston. Mahle weight of blank piston supposed to be 489g, however, I do not have calibration weight to check scale either.
Old 11-21-2021, 08:11 AM
JoeMag's Avatar
…got a calibration weight and my scale is dead on at 500g.
Old 11-22-2021, 03:23 PM
Administrator
Just weighed a new Mahle Motorsports 102mm piston, no rings or pin: 482g.
Old 11-24-2021, 10:24 AM
JoeMag's Avatar
Black 993. - could u post a pic of piston? There’s the 11.4 one that I have and a 12.3/4 one that is lighter.
Old 11-24-2021, 02:30 PM
Administrator
I can get it out of the box again if you want to see pics but it's the 11.4 spec. Just got the set. Slip-fit 102mm's. I weighed it on a digital postal scale I've had for years. Probably pretty accurate but obviously this isn't a measurement from the Livermore Laboratory.
Old 11-24-2021, 07:35 PM
JoeMag's Avatar
Ok, thx… Mine does have some carbon on it but looks pretty light. Without a doubt they’re weighed and put into different weight groups in manufacturing. I do have another one like the pic and it’s 500g too.
Old 11-25-2021, 06:24 AM
