Best current rear main seal ?
911 1967.
Rebuilt engine. 200 miles. Just got home 1st impressions the rear main is running out quite bad. Up until now it's been dry. Elring made in Italy fitted. Will investigate on Monday but until then what seal is recommended. Lyndon |
I recommend original Porsche… had same problem as you until i fitted original
My 69E project ... http://www.youtube.com/user/ditster666 |
Lyndon |
Lyndon,
Did you install the rear main seal dry or with some type od sealant? Thanks, Rahl
1976 930 turbo Carrera, "Ubich". Mostly stock, lightly sweetened. She’s an angry schwierigkeit. She doesn’t want flowers, she just wants to dance! And when she does, she shakes her hips to the rythem of the road. Drive her like you hate her! |
Most recommend installing the rear main seal dry.
Rahl
