ring compressor tool for 3.3 engine
what size ring compressor tool is needed for a 3.3 turbo engine?
Thanks Lorne M.
83 SC |
Bore Diameter.........
Brew Master
I can't tell you the size but after using the Wiseco ring compressing sleeve, I'd recommend getting one. I used one my brother loaned me. No real worry about breaking rings by having one catch.
If what I found online is correct, you have a 97mm bore. The model for my 3.2 was RSC09500 Yours would be RSC09700 Here's a video my brother did of the ring sleeve in action. Only note would be to load the piston from the bottom rather than the top because of the taper the cylinders have.
Nick Last edited by cabmandone; 12-08-2021 at 10:58 AM.. |
Easily Confused
+1 for the Wiseco. You can get them at Summit racing online.
Scott C. '08 Cayenne GTS 6MT : '89 Targa GP White/Black - "Oliver's Car" : '11 Mitsu Evo X : '08 Lexus IS350 F-Sport : '01 Toyota Sequoia : 1998 Yamaha V-max : 1979 BMW R65 |
Any compressable style tool will work. But, we get the solid tapered sleeve style ones for every application we build. The tapered sleeve style is very easy to use, where the compressable style work well, but are not as easy to use.
Hope that helps. Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Puny Bird
^agree I've moved to the Wiseco sleeves, for 356 and many VW I have the factory tools.
In a pinch I still use a generic ring compressor, it can be done, but they're not well suited for the aircooled engines.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
Hazet adjustable strap style works well.
