ring compressor tool for 3.3 engine
what size ring compressor tool is needed for a 3.3 turbo engine?
Thanks Lorne M.
83 SC
Old 12-07-2021, 02:49 PM
Bore Diameter.........
Thanks Lorne M.
The bore diameter (mm) will determine the size of your ring compressor tool.
Tony
Old 12-07-2021, 06:52 PM
Brew Master
cabmandone's Avatar
I can't tell you the size but after using the Wiseco ring compressing sleeve, I'd recommend getting one. I used one my brother loaned me. No real worry about breaking rings by having one catch.
If what I found online is correct, you have a 97mm bore.
The model for my 3.2 was RSC09500 Yours would be RSC09700
Here's a video my brother did of the ring sleeve in action. Only note would be to load the piston from the bottom rather than the top because of the taper the cylinders have.
Nick
Old 12-08-2021, 10:38 AM
Easily Confused
dtxscott's Avatar
+1 for the Wiseco. You can get them at Summit racing online.
Scott C.
'08 Cayenne GTS 6MT : '89 Targa GP White/Black - "Oliver's Car" : '11 Mitsu Evo X : '08 Lexus IS350 F-Sport : '01 Toyota Sequoia : 1998 Yamaha V-max : 1979 BMW R65
Old 12-09-2021, 03:47 PM
Jeff Alton's Avatar
Any compressable style tool will work. But, we get the solid tapered sleeve style ones for every application we build. The tapered sleeve style is very easy to use, where the compressable style work well, but are not as easy to use.
Hope that helps.
Cheers
www.turn3autosport.com
Old 12-10-2021, 07:28 PM
Puny Bird
Mark Henry's Avatar
^agree I've moved to the Wiseco sleeves, for 356 and many VW I have the factory tools.
In a pinch I still use a generic ring compressor, it can be done, but they're not well suited for the aircooled engines.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 12-13-2021, 06:37 AM
Hazet adjustable strap style works well.
206 637 4071
Old 12-16-2021, 06:36 AM
