Looking for P201 Engine Yoke Source
Hello, I am planning a to do a top end rebuild on a 3.2 and struggling to find a reliable source for a quality P201 Yoke. It looks like our host is no longer offering this tool, so I would appreciate some input on recommended sources. Thanks in advance.
Old 01-21-2022, 04:39 PM
Check eBay. It’s been six years but that’s where I found my excellent P201 clone with correct semi-circular flange; Chinese-made. There are lighter-duty versions but I think they’d represent a false economy.
John
82 911SC coupe
Old 01-21-2022, 06:13 PM
Racer
winders's Avatar
I bought one from here last year:
PEL-TOL-P201
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 01-21-2022, 06:36 PM
Try not, Do or Do not
Henry Schmidt's Avatar
https://www.qscusa.com/collections/porsche/tools
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 01-21-2022, 06:45 PM
Racer
winders's Avatar
You'll have to go with Henry's suggestion as I tried to find the yoke here on Pelican and it is not there any more. Ironically, there is a picture of it on the link to the Porsche specialty tools but no yoke listed.
Scott Winders
PCA GT3 #3
Old 01-21-2022, 07:37 PM
It's a 914 ...
stownsen914's Avatar
If you're looking for lower cost options, as suggested search eBay. I bought a 5 arm one a couple years ago, quite inexpensive. It's quite sturdy, not cheaply made at all. Couldn't find it just now, not sure if that shop is still making them.
Old 01-22-2022, 04:28 AM
The link I offered was a direct link to the EBay seller.
I list the company with some reservation (personal experience) as I find this Chinese manufacturer to have some Quality control issues but for this product, they are cost effective.
Henry Schmidt
Ph: 760-728-3062
Old 01-22-2022, 06:00 AM
Titanium User
Originally Posted by Henry Schmidt View Post
All sold out. Make a WTB ad in the parts forsale forum and you'll probably find a member who has one in the garage they won't be needing.
Buy some Titanium Lug Nuts!
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1032311-fs-titanium-lug-nuts-studs-v2-0-a.html
ig: @ti_porsche_products
Old 01-22-2022, 06:04 AM
If you can wait I just ordered the steel last week to make the simple U shape adapter that can be used on any auto parts store engine stand.
I'm waiting on the water jet company to tell me the cost to cut. I'm make 10 of these to start.
Old 01-22-2022, 08:36 AM
It's a 914 ...
Found the one I was referring to, on another forum.
I think I saw a post here once that there was a clearance issue with the oil cooler? Mine is a race engine with the cooler deleted. It worked well for me.
https://www.thesamba.com/vw/classifieds/detail.php?id=956239
Old 01-22-2022, 09:00 AM
Puny Bird
Mark Henry's Avatar
I made one like that, IIRC the center arm interferes with putting the T4 #3 piston pin in. I had to modify, notch the arm.
I also made my 996 mount.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 01-22-2022, 11:22 AM
It's a 914 ...
I believe the same vendor makes 3 and 4 arm yokes, in case that would help with what mentions above
Old 01-22-2022, 05:22 PM
Jeff Alton's Avatar
Those thin flanged mounts do not allow you to mount the engine with the oil cooler and rear sheet metal installed...
We have 3 and use them for our gearbox builds. Work perfect for that. There is a reason we have 4 P201 mounts. Get a P201 or decent replica for engines.... Then you can likely sell it here on the classifieds when you no longer need it.
www.turn3autosport.com
Old 01-25-2022, 08:57 PM
Thanks for all your replies, I have decided to order the QSC P201 tool.
Old 01-27-2022, 07:37 PM
Any follow up on the QSC yoke? It looks like there is only one model for the “911” as far as I can see. “QSC 356 911 930 914” looks like a reasonable alternative
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 01-22-2023, 06:26 AM
Senior Member
Vertex?
Chris
1988 911 Carrera Targa (driving project started JAN 2022)
1970 911E - Long since gone
1972 911 Targa - gone
1987 911 Carrera - gone
Retired FA-18C Driver
Old 01-22-2023, 10:20 AM
Jeff Alton's Avatar
We have 6 of them (proper thick flange ones), from various supppliers. Forgot where we go them all. A couple we have ground some reliefs into to make them work perfect. Simple to do.
We have 3 flat flange ones and use them on 912/356 motors and gearboxes only.
I do believe or M96/97 ones (4) are from QSC and they all worked perfect out of the box.
Cheers
Old 01-22-2023, 06:37 PM
Senior Member
Jeff - as a relative noob headed towards my fist engine drop to do the clutch, any recommendation for the engine stand. Plan on addressing some back of the engine items as well as setting valves, and new oil return tubes. I'd like to get a reasonable stand that is easy to maneuver and allow access where I need it...
Thanks.
Chris
Old 01-23-2023, 06:03 AM
It's a 914 ...
I have the standard Harbor Freight stand, works fine for me with the 911 yoke.
Old 01-23-2023, 11:03 AM
Jeff Alton's Avatar
For a stand, get one with a square leg design, not a "Y" or one with a leg down the center. The square leg style allow you to move a floor jack or lift table into the center to lift the engine to a height where you can slide the yoke into the stand....
This style
Old 01-23-2023, 09:37 PM
