Chain fence eating turbo
Originally Posted by hbrand View Post
I think it can be pressed in. A threaded rod with small sockets and nuts should work.
I don't follow?
Old 02-06-2022, 09:01 PM
theiceman's Avatar
when you put the orings in did you use a lot of oring lube ? if so i would crawl under with a pillow to support my head ... gob a ton of lube in there.. and work it back in with one of those plastic ineterior trim tools. Id put a hose clamp around the return tube so it can be grabbed and turned as i worked it back in a tiny bit at a time ...
Why would i do this ?? because you have absolutely nothing to lose... if it doesnt work crush it, pop it out and from this point forward when you are under your car you have a reminder to " do better"
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 02-09-2022, 08:28 AM
Walt Fricke's Avatar
The two piece tubes work just fine. I always use one next to the oil pump fitting, so I can get a normal wrench on the fitting should the need arise. So not to worry you built in a weak point.
Old 02-10-2022, 07:41 AM
Yes sir, what I tried. The problem is there is so much compression on this O rings, it's impossible.
Old 02-10-2022, 06:41 PM
Yeah, I'm not taking a chance on damaging something over a silly oil return tube
Old 02-10-2022, 06:42 PM
Find a couple of Wrightwood Racing green viton o-rings. They're softer and go in nice. Use silicone paste. Oil won't work.
206 637 4071
Old 02-11-2022, 04:40 PM
I thought the VR kit had Viton as they're green. I did use Wrightwood on the low end as I've heard that VR had a problem with the square O-rings between the cases for the oil pump having QA issues with pumps cavitating.
Silicone grease was used, I still can't believe this happened and I didn't check my work!
Old 02-13-2022, 07:05 AM
Do this long enough and you may have 1) put the heads on without the one piece return tubes you bought on one bank, and not discovered this until you had put the cam carrier on, and maybe installed the rockers and timed the cam.
2) Put the right side cam in the left side, or timed #1 and #4 backward.
3) Put a head or three on upside down (at least this is noticed earlier rather than later.
Having a good engine stand makes all the work easier, but being able effortlessly to rotate the engine can allow getting mixed up on which side is up. Not that any of these problems aren't easily avoidable.
Old 02-14-2022, 01:29 PM
HAHA, Walt, happens to the best of us.....
Old 02-16-2022, 11:24 AM
theiceman's Avatar
ive done a couple of these, im not admitting which ones.
Old 02-16-2022, 11:38 AM
Have you fixed this problem?
Tippy,
Have you decided which direction to take to get this nagging problem solved? I don’t think the big viton o-ring for the oil return tube could be forced to slide back in without damaging or compromising the sealing property of the o-ring. Keep us posted.
Tony
Old 02-20-2022, 05:40 PM
Alan L's Avatar
Ha, 1 &2 sound familiar
Tippy, you have tried what I would do - some upholstery type tool and lube. I get you on the compression. One other option might be a heat gun, Plus above.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 02-20-2022, 08:40 PM
Originally Posted by boyt911sc View Post
Tippy,
Tony
Tony, bought a collapsible tube,I'm just not going to jeopardize damaging something tearing the engine down over a superficial part
Old 02-22-2022, 05:19 PM
Alan
I tried heat with lots of grease to no avail. Way too much compression on those monsters
Old 02-22-2022, 05:20 PM
