short gearing enhances torque across the board, shorter tires or shorter cwp all the time and shorter individual gears while they are engaged vram( length change of the intake tubes) enhances torque in all gears but only in the lower to mid rpm ranges the variable geometry intake manifolds used in the 964/993/997/991/992 enhance torque somewhat unevenly across the full rev range
I just found out that the pistons are out of the required specs. New pistons are not cheap for these engines. I may have to shelf the intake upgrade for the moment. Is there any harm in using a used O.E intake, TB and twin plug on a rebuilt engine?
