header size
For a track car, 3.0 engine, 11.8 to 1.0, D60 cams, MFI, twin plug. What size header do want for that set up, OD/ID. Thanks, Bob
Old 05-05-2022, 07:23 AM
Puny Bird
Mark Henry's Avatar
I'd go with the 1-3/4" primary pipes or at least 1-5/8".
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 05-05-2022, 11:38 AM
My thoughts; 1&5/8. I'd think 1.75 might be a tad large for a 3.0?
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 05-05-2022, 11:57 AM
Racer
winders's Avatar
1 5/8" for sure. 1 3/4" is too big for a normally aspirated 3.0L.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 05-05-2022, 12:31 PM
Puny Bird
Mark Henry's Avatar
Your engine has a pretty healthy build spec 1-5/8" would work, ID is ballpark 1-1/2"
I have a 914 with a similar spec 3.0, except webers with big ports and 1-1/2" headers. It's a street car so I haven't been chasing HP, but I picked up a soup to nuts twin plug EFI system so I'm going to 1-5/8" headers.
Old 05-05-2022, 05:22 PM
Bill Verburg's Avatar
What's the rpm range, muffled or not
but most likely 1 5/8" ID which is ~1.75" OD
Bill Verburg
Old 05-06-2022, 04:32 PM
Racer
winders's Avatar
No. 1 5/8" O.D. is the way to go here. Theory versus reality here.....
Scott Winders
PCA GT3 #3
Old 05-06-2022, 05:04 PM
Racer
winders's Avatar
Let me give more perspective:
I had a 3.6L race engine with stock 1995 993 EFI intake system and 1 5/8" O.D. headers (not with overly thin wall tubing) make over 320 HP. Testing indicated that the intake was the limiting factor as more power could be made with a larger throttle body. I now have a 3.6L race engine with 45mm AT Power ITBs and 1 3/4" O.D. headers (again, not with overly thin wall tubing) make over 430 HP.
There is no way the 3.0L engine described needs more exhaust flow than what 1 5/8" O.D. headers would provide. In fact, the 1 3/4" O.D. headers would hurt power output especially under 6000 RPM.
Scott Winders
PCA GT3 #3
Old 05-06-2022, 07:26 PM
header size
72-7500 RPM and a set of Burns megaphones. A 2''straight shot through a muffled shell. Bob
Old 05-08-2022, 04:20 PM
Under the radar
Trackrash's Avatar
Bill. How does this flow graph relate to pipe size? What am I missing?
Gordon
'71 911 Coupe 3,0L outlawed
Old 05-08-2022, 04:30 PM
Jeff Alton's Avatar
diameter is only part of the equation. That said, a 3.0 NA motor should not need more than 1 5/8....
www.turn3autosport.com
Old 05-08-2022, 07:24 PM
Pipe diameter goes up with the square root of flow, so the graph shows you how you need bigger pipes if your redline and desired power band are higher than if they are lower.
Sent from my SM-G988B using Tapatalk
Old 05-09-2022, 10:57 AM
Under the radar
Trackrash's Avatar
Right, but I don't see any relationship to pipe diameter in the graphs.
Gordon
Old 05-09-2022, 12:53 PM
Pipe diameter required changes with flow, so I think the point is, until you state your redline and power band, nobody can answer.
Old 05-10-2022, 12:59 AM
You'll notice that 8k a 2.7 processes the same volume of intake air as a 3.8 @ 5.5k under theoretical condition of 100% volumetric efficiency
the 2.7 operating up to 8k may want the same exhaust as a 3.8 operating to 6.5k
general rule of thumb for the eigen values of stockish street motors all ~31" primaries +/-
to 3.0 1 3/8" ID
to 3.4 1 1/2" ID
to 4.0 1 5/8" ID
Bill Verburg
Old 05-11-2022, 05:28 AM
Racer
winders's Avatar
Maybe on the back of a napkin….but never in real life.
Scott Winders
PCA GT3 #3
Old 05-11-2022, 07:40 AM
Under the radar
Trackrash's Avatar
to 3.0 1 3/8" ID
to 3.4 1 1/2" ID
to 4.0 1 5/8" ID
That makes sense. Although I have seen formulas that predict flow and velocity related to RPM and cylinder volume.
Gordon
Old 05-11-2022, 08:15 PM
