info on this EFI slide valve setup
just bought a race car with this slide valve setup. can anyone advise of the brand? looking for info so I can sell it.
thanks in advance
Old 04-18-2022, 12:50 PM
It's a 914 ...
stownsen914's Avatar
A 914 with slide valves - nice
Old 04-18-2022, 01:29 PM
scootermcrad's Avatar
Can you tell if the slide body is cast and post machined? Sorta looks all machined, but the pockets (black?) almost look to have casting marks in them.
Nifty setup. How do they run?
Old 04-18-2022, 01:40 PM
jmz jmz is online now
jmz's Avatar
possibly old ProTechnik slides.
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud)
'70 914/6 Race Car (Faster and Louder)
'71 73RSR tribute vintage race car 3.0
'68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox
'81 Magenta IROC clone in progress 3.6 varioram/G50
Old 04-18-2022, 02:04 PM
everything looks machined alum. the dark arears are just dirt/grime. everything runs very nice, I just want to switch to carbs
Old 04-18-2022, 02:19 PM
Turbonut
Raceboy's Avatar
Why would you switch to carbs if you have one of the best possible setups??
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet
http://www.facebook.com/vemsporsche
Old 04-19-2022, 10:26 PM
im not good with efi/ecu tuning... I like to keep it simple.
Old 04-20-2022, 04:15 AM
JmuRiz's Avatar
I’d buy that for a dollar, cool looking setup.
'73 2.0 914 (2.8 /6 conversion in progress)
'64 356SC
'65 Ducati Falcon 80
‘19 Audi SQ5
Old 04-20-2022, 07:53 PM
Registered Minimalist
75 911s's Avatar
any idea what the valve size is?
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 04-24-2022, 11:51 AM
safe's Avatar
Get the car to a tuner with dyno and let him adjust it, then leave it alone.
Easy as that. Simple.
Magnus
Old 05-11-2022, 05:13 AM
Depends on what engine management system you have and its tuneability. On another issue, how does one get around the pooling of fuel on top of the slide plates at idle. Once on the track, I am thinking maybe better atomization of the fuel. I have the option on my stacks to go either way and at present they are down below the slide plates. I am MFI, not EFI . Thinking out loud. Bob
Old 05-12-2022, 07:24 AM
Talking about the injectors installed above the throttle plates.
Old 05-12-2022, 07:26 AM
