Whats best distributor for 2.5
Guys
I am building a 2.5 with DC30 cams and Italian Webers .
Whats best approach for Distributor?
Thanks for advice/recommendations
Frank
Gold71
Old 04-26-2022, 10:45 AM
123 distributor
123 ignition USA .com
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 04-26-2022, 12:20 PM
Icarp
Thanks but staying more old school
Researched and read but not interested
Appreciate the suggestion tho
Frank
Gold71
Old 04-26-2022, 04:28 PM
If not 123, another good choice is Supertec distributor that I think Aaron Burnham designed? Research those threads here; good design and old school. I am assuming you’re doing 2.5 twin plug but believe they have single plug too.
Choice for twin plug after 123 and Supertec would be JB racing twin plug which performs good but lacks the old school look of Supertec one.
Old 04-27-2022, 01:49 PM
Thanks for options …..will reach out to Henry and Aaron
Regards
Frank
Gold71
Old 04-27-2022, 03:10 PM
Try not, Do or Do not
Henry Schmidt's Avatar
We did a new design after Aaron stopped building them.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 04-28-2022, 09:54 AM
To my surprise…..Seems i am starting to be swayed to 123 ignition .
Seems Henry has some positive thoughts as well
Looks like they have now packaged the ignition, coil, wire set and spark plugs.
Described to be for 2.4,2.7 engines.
Assume all to be compatible rather than worrying about compatibility of mixing original components.
Has anyone used their integrated package?
Gold71
Old 04-29-2022, 06:02 AM
Rosco_NZ
Send a message via Skype™ to Rosco_NZ
123 also have a twin plug distributor .. seems to only appear on their German website ..
Old 05-01-2022, 12:48 PM
They are also made by Mittlemotor (using 123 internals it appears) and are available through Sierra Madre as well. It’s hard to find them listed on the SM site though (no affiliation). I only bring it up because, occasionally, SM has really good coupon code and you can save a fair amount on one. I like the Mittlemotor version because it looks very similar to an original Marelli twin plug distributor so it looks better in my opinion. They can also be used with stock CDI boxes and coils.
I picked mine up a few months ago (on a 20 or 25 percent off coupon) although the engine is still being built so I don’t have any additional feedback.
Stretch
Old 05-02-2022, 03:39 AM
No reverse gear in life
this is where Differs got my full set up when restoring my car - Differs in NL (former twinspark)
shop
David Alstadter - There is no reverse gear in life!!!
74 911 2.7 Carrera 9114400120 - licht grün
71 911T 9111121235 - recreated as 2.8 RSR glasur blau (3.0 MFI)
73 911S 9113301270 - silber metallic (sold)
72 911T - bahia rot (2.8 RSR) SCCA ITGT 95 LA & SD champ (sold)
Old 05-03-2022, 06:50 AM
