'72/'73 2.4L/2.7L GE Head Gasket
What is correct side to face cylinder head?
The GE head gasket on a 1973 2.4/2.7 that seal the cylinder to the head is not symmetrical. One side of gasket seem longer and sharper, and hides the spring inside the gasket. The other side seems a bit rounder and there is a bit of exposed spring. The gasket sits proud of groove in cylinder with spring in and fit inside with spring out. Thank you. |
You most assuredly want the edge that sets proud so there is some crush taking place
Bruce Last edited by Flat6pac; 07-03-2022 at 04:48 PM.. |
It actually sits proud regardless of side. Is there a definitive side that faces the head?
Long edge to the cylinder, but it really doesn’t matter
Long edge to cylinder feels better than other way around.
Agreed.
