Solution for valve clearance needed
Having attempted the Bruce Anderson 2.2 to 2.5 conversion and started final assembly I discovered I have Zero valve clearance
The only 2 alternatives I have come up with so far is adding 3x .5 mm base gaskets,
which will unfortunately lower the C/R or start again with pocketed pistons.
Old 09-23-2022, 02:45 PM
Under the radar
Trackrash's Avatar
Those pistons were designed to work with the anemic CIS cams in the 2,7 motors.
I'm guessing you have either carb, MFI or other hot cams?
If that is the case, your best bet is to get pistons designed for use with performance cams.
Gordon
'71 911 Coupe 3,0L outlawed
Old 09-23-2022, 04:25 PM
Try not, Do or Do not
Henry Schmidt's Avatar
A 2.7 CIS piston (8:1 compression) on a short stroke crank makes 7.2:1 compression maybe. New pistons make sense. If low compression works for you,
I have a nice set of used Mahle 2.7RS pistons with new Goetze rings you can buy for $ 1,000.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 09-23-2022, 04:38 PM
I'm using the original 1970 T cams but didn't realize they were incompatible .
I may well be interested in the Mahle pistons and rings Henry , If you could send some pictures and an shipping estimate to Ontario Canada I would appreciate it.
Richard
Old 09-23-2022, 07:23 PM
Richard
Here is the piston and cylinder set. I would be willing to sell the pistons and rings separately.
Shipping depends on method. I would guess $ 85 USPS.
Henry Schmidt
Ph: 760-728-3062
Old 09-24-2022, 10:37 AM
Thanks Henry , what would be a good time to call you ?
Old 09-24-2022, 02:44 PM
8:00 to 10:00 AM Pacific time. That way I will have had my first cup of coffee and maybe not so grumpy.....
Henry Schmidt
Ph: 760-728-3062
Old 09-25-2022, 04:36 AM
I will give you a call Monday morning.
Old 09-25-2022, 10:04 AM
Sorry, forgot to mention we work Tuesday-Friday.
Closed on Mondays.
Henry Schmidt
Ph: 760-728-3062
Old 09-25-2022, 01:09 PM
