P234 rear main seal tool available?
Getting ready for my JE piston set 73 2.4L rebuild 911T and in need of the p234 or equivalent rear main seal install tool. Is there one floating around this forum to buy? I only need one use (hopefully) so it isn’t really economical to buy a new unit.
Where are you?
Small plastic hammer. Cheap.
I’ve got that tool, the best part about it is that it’s fool proof. Tapping in is just as good as long as the seal stays square - if they are at all crooked it’s a leaker
it's not leaking....it's just marking it's territory |
We have the tool as well, I rarely use it, but our techs use it all the time... It is fool proof and creates consistent repeatable results, which is important in a shop environment.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 Last edited by Jeff Alton; 10-14-2022 at 08:48 PM.. |
Home made P-234 tools.........
Go to your local hardware stores and look at the plumbing section for these pvc parts or find a scrap steel plate.
![]() ![]() ![]() Tony |
The one advantage of the tool is that it sets correct depth.....
cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Or is it just mitigating the risk of hammering too hard and squishing the seal in some way? D. |
The original post mentions a 73 crank so he actually needs p215 which also just drives the deal flush.
A lathe pays for itself really fast when you need NLA or $$$$ tools.
On installation, I would generally fit a seal (using a "screw" tool like the above) until the seal bottom end sits against something (like the case). If it happens to be "flush at the other end" because of the seal dimensions, then "so be it". Is this foolish for a 9 hole flywheel crank seal (or any other), and it would be better for it be "flush" regardless of whether the bottom edge is up against the case? |
Strictly, The depth of the circular cavity is several mm more than the thickness of the rear main seal. So if you install the oil seal flush to the edge, there is still several mm clearance before the backside comes in contact with the crankcase. I have some measurement done years ago and if my memory serves me right, the space is about 3~4 mm clearance. Basically, the green PVC and the steel plate work the same way as pressure plates. The three (3) bolts are tighten gradually to push the oil seal smoothly and flush to the case. I use the same bolts for the PVC and the steel plate. The bolts shown in the picture for the steel plate were my proto-type fasteners I just picked from the tool box. The regular hexagonal head bolts are what you need. Nothing fancy. Tony |
Easily Confused
Super Big Gulp cup from 7-11 worked for me.
Here's the writeup Flywheel side crank seal installation
Scott C. '08 Cayenne GTS 6MT : '89 Targa GP White/Black - "Oliver's Car" : '11 Mitsu Evo X : '08 Lexus IS350 F-Sport : '01 Toyota Sequoia : 1998 Yamaha V-max : 1979 BMW R65 |
