Anders
Anders.'s Avatar
ARP bolts touching inside of case
Hey. I have a problem where my newly installed ARP rod bolts is slightly touching the inside off the engine case. Is this a known problem? In the pictures you can see where it has slightly shaven off magnesium shavings. Is there something I can/ should do about this?
-Anders
Old 10-29-2022, 01:37 PM
What engine and what part number for the bolts?
206 637 4071
Old 10-29-2022, 02:27 PM
ARP Rod bolt part numbers.
206 637 4071
Old 10-29-2022, 04:05 PM
You should fix this, luckily you can remove the rods without splitting your case…maybe you change out the bolts. What case crank and rods do you have?
it's not leaking....it's just marking it's territory
Old 10-29-2022, 07:07 PM
Racer
winders's Avatar
But can he remove all the metal flakes without splitting the case?
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 10-29-2022, 07:10 PM
Under the radar
Trackrash's Avatar
Are the pistons installed? And the bolts are hitting when rotating the entire crank, rods and piston assembly? I ask because the rods can hit without the pistons guiding them in their correct alignment.
Gordon
'71 911 Coupe 3,0L outlawed
Old 10-29-2022, 10:50 PM
Your gonna have to split the case and get rid of all those shavings and do a proper inspection.
Old 10-30-2022, 06:49 AM
