do I need to hone this?
Does this nicasil cylinder need to be honed to have rings seat?
Cross hatch is still clearly visible. Thanks, Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Friend of Warren
I did. I used a flex hone on mine. About 3-4 passes on each cylinder. Now have about 1500 miles on the rebuild and so far using NO oil! Here is a picture of one of my cylinders during the tear down and you can see that it look identical to yours. My concern was that the cylinder wall was too slick looking and the rings wouldn't seat. Flex honing gave the walls a much duller look.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Thanks, I think I will send them out to a place here that has diamond hones and see what they think.
Cheers, Jeff
My 3.3's looked the same after 100K miles. I measured the clearances and they were only half way to the clearance tolerance. I am sending them to be honed just to be sure.
Norm '86 930 AEM Infinity 6 - Twin Plug 3.6L - DBW - JE Pistons/LN Eng. Cylinders - Pauter rods - GT3 Crank - GTX3584RS - ID1050x Injectors - Ported Intakes - Custom Intake Manifold, exhaust and intercooler - 993SS cams - ECUMASTER PMU-16DL HRE Wheels 560R 8.5x18 ET25 (Front) 11x18 ET0 (Rear) |
Friend of Warren
Why not just buy the flex hone for $50, chuck it up in a drill and do it yourself?
good Question?!?
Actually I have a grape hone but was kind of unsure whether to use it or not. If I use it, would I just pull it through a couple of times? I don't want to damage the cylinder walls.
Friend of Warren
Yes just lube the cylinder walls up with some 20w50 (actually and motor oil will work just fine) Use a drill with about a 500-700 rpm speed and move it up and down in the cylinder 3-4 times making sure you push about a third of the hone out past the bottom of the cylinder and up through the top of the cylinder to make sure you hone all of the cylinder. Not much danger of hurting the cylinder walls with the flex hone (what you call the grape hone) that is why Wayne and others recommend its use. It really doesn't "hone" the cylinder like the hones that use the 3 honing stones do. It just scuffs it up a bit.
Kurt V...Thanks for the encouragement
Hi,
Could you post a picture of before/after honing ? for us novices could be interestig to see the difference. Maybe even the 'flex' hone. Thanks, Michael |
Try not, Do or Do not
No No not a hone !!
It has been our experience that if you hone Nicasil cylinders the hone cuts into the Nicasil and because it is so hard that the new ridges are too abrasive on the rings. The rings will seat but they will not last as long as they would if the cylinders are prepped properly. We have had great results from Scotch Brite with soap and water. This breaks the glaze but doesn't cut the Nicasil. Don't forget to check for roundness. I've seen Porsche cylinders .004 out of round.
P.S. use only Goetze rings. Hastings in a pinch.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 05-21-2004 at 07:09 AM.. |
Author of "101 Projects"
As I state on page 55 of the Engine Rebuild Book, "You should only have an expert familiar with the Nikasil cylinders perform the honing process."
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Slumlord
Why hone if the cylinder walls are not glazed?
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
Air Medal or two
Sometimes you guys scare me!....I wont flame you, but I wish you had asked the Q. b4 you did it!!! So next time just dont
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
Afterburn, is your post directed at me? If it is, I am not sure I understand.
Jeff
Air Medal or two
It is directed to anyone that would break out a nasty hone on that Gourgous cyl!.......please don't
Very well, thanks.
Jeff
Air Medal or two
The wall on that is SOoo thin.....you go thue to the aluminum in a hurry!
Unoffended by naked girls
A grape hone is not hard enough to remove Nikasil, unless the cyl has been gouged and the coating is already flaking.... Or, just Scotch-Brite it as someone else mentioned.
Dan 1969 911T (sold) 2008 FXDL www.labreaprecision.com www.concealedcarrymidwest.com |
Friend of Warren
