Just the smoke out the exhaust. I haven't driven it enough to really read the plugs but they're jet black. I will have the car back this weekend I think, then I can , if it's driveable, give it a whirl under load for maybe a few miles and see what it does. I'm not even sure the rings have seated, since there's under 10 gallons of gas run through the motor and all of it is idling or working on the carbs, no actual driving.
Old 11-29-2022, 07:42 AM
Coblue, looks like you’re having your own issues beyond carburetors.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 11-29-2022, 12:32 PM
what do you mean?
Old 11-29-2022, 01:07 PM
Oops, that didn’t sound right. I mean with your engine. Other issues like ignition, or mechanical engine issues.
Old 11-29-2022, 03:25 PM
I am hoping there are no mechanical issues. If it isn't in the carburetors, or the valve adjustments, I think it almost has to be in the ignition, which is a 15 year old HPV-1. I think Mayo's shop can at least tell me what the problem is without costing three fortunes. We'll see. Meantime I think I',m going to try driving it around the block over the weekend.
Old 11-29-2022, 05:17 PM
Got the car back! Hard to put in reverse, some of the gauges don't seem to work. but it's back in my possession. Have an alignment scheduled for Wed Dec 7. We'll see what happens!
Old 12-02-2022, 11:11 AM
I apologize for hijacking this thread. I apologize to the original poster.
Old 12-02-2022, 11:12 AM
H-viken's Avatar
No worries man
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452)
911E Coupe -70
Carrera 3,2 -84 Sold
Old 12-02-2022, 12:48 PM
Charlie at Innovative Automotive has the car now, he is tracking misfires on cyls 4 and 6 and both cylinder bqanks are running very rich.
I gave him the go ahead to explore for a few hours and we'll talk tomorrow.
Old 12-08-2022, 01:25 PM
Plugs 4 5 and 6 are fouled, not sure if they are oil-fouled or fuel-fouled. Second mechanic says he thinks the 'reverberations from the cam are disturbing the fuel flow'. I dunno, maaaannn...goes to Mayo next week.
Old 12-12-2022, 02:52 PM
Vibrations can cause problems carburetor's. I recently had an issue with resonance causing my needle valves to open, which overflowed the bowls. It turned out to be caused by the stainless engine crossbar, when I went back to stock the carburetors cleared up.
Old 12-12-2022, 05:50 PM
the crossbar being the crossmember the engine mounts run through to mount the motor?
Old 12-13-2022, 10:43 AM
Car will be going to Mayo's on Monday. I set this appointment up in October sometime, he has a 6 week or so wait list. Hopefully he will be able to dial it in a lot better. OR make recommendations on what to change.
Old 12-13-2022, 07:08 PM
Yes.
Old 12-14-2022, 03:45 PM
Talked to the guys at Mayo today and found that I didn't get what I [aid for from the *****s who but the motor. Instead of 993SS cams I got what they called 'the second biggest cam you can put in a 3.0' but they didn't name names. Finding that out meant they could set the timing correctly for it, and they've done that and are still tweaking, but the guy decided to drive it to the gas station to get some gas and said it was 'really streetable' and 'sounded fantastic from the driver's seat'. with excellent performance characteristics and no blips to speak of on gear changes. I am quite encouraged!
Old 12-23-2022, 01:55 PM
Glad you got it worked out. Now for the YouTube video of it on a drive. Great sounding motor and exhaust
Old 12-24-2022, 12:44 PM
No youtube account here. Maybe get someone to share one though
Old 12-24-2022, 05:57 PM
