head temp sensor and unknown part or plug?
Happy new year pelicans: Am tearing down 3.2 carrerra 88 for valve suides I think.
Found this splice? in line. Is this normal or okay? Also found plug or something on top of engine behind the alternator. Anyone recocnize this part? Tks for help. trying to post pics ![]()
add pic
that el.connector i`m not sure it will work since there should be insolation cable and inside pick up wire of the temp....but all is possible..
the plug is from your AFM air flow meter ,where do you adjsut the fuel mix look here.. ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
lake wales fla
The single wire sensor used the cyl head for its ground point and the 2 wire used a dedicated ground so that rig would work and appears that it has but if I was the OP I would be changing that thing out for an OEM 2 wire as a preventative maintenance as opposed to being stranded on the side of the road. Richard |
Tks Guys: Had not seen response due to holiday I guess so I spent hours poring over
parts manuals and finally fount that plug. Thought that what it was as our japanese m/c carbs used to have same thing after all the smog crap. Found a new head temp sender and will replace with new 2 wire style. Also speed sensors are all losing their insulation so they go too! Thanks again and I am sure I will have many more questions later. Rebuild my 2.4 30 years ago and she is now still going strong in Greece! |
