oil filter console
Does anyone know of a remanufacture of the 2nd oil filter console, #930 107 057 01. Bob
Old 02-09-2023, 12:14 PM
I bought one a few years ago new from Rose Passion. The exchange from USD to Euro was in our favor and discounted. I know they are still available NIB, likey $400-500 bucks.
https://www.rosepassion.com/en/entry-reference/930-107-057-01#zone_saisie
Old 02-09-2023, 03:03 PM
Bill Verburg's Avatar
You can also use the 993 version, same thing
you will also need the cover, there are 3 versions, which one you need depends on the crankcase
drilling the 964 or earlier block is easy, and both the 930 and 993 part bolt on
Bill Verburg
Old 02-09-2023, 03:32 PM
Thanks for the response. I will give Rose Passion a shot tomorrow. Both the 965 and 993 are on no ETA according to my dealer. My plan now is that I have an early oil filter flange that bolted to the early oil tank. I can make a plate the shape of the oil cooler flange, machine a block of alluminum to bolt to that, drill/mill appropriate holes to mate up with my early oil filter flange and I have a console. A good bit of work, but what is one to do. Bob
Old 02-09-2023, 04:18 PM
My experience with RP is if they say they have it they likely do. Last time I ordered a GT3 pump from them it was shipped in a day. Expected to arrive in 2 days. DHL was the issue at the time. If you end up ordering from them I would request/call them and tell them explicitly you do not want DHL. DHL fudged the paperwork so bad last time the shipping was refunded and they held my part for a week until I payed customs fees which where not required. Avoid DHL at all costs.
Old 02-09-2023, 04:31 PM
The 9 Store
DHL is the worst. A big mess pretending to be a professional company.
All used parts sold as is.
Old 02-09-2023, 05:48 PM
Don't forget the cover, there are 3 different non interchangeable versions, 2 work w/ the engine mounted filter but which to use depends on the specific crankcase
Bill Verburg
Old 02-10-2023, 09:44 AM
I tried to buy the one from MS roadrace about a year ago. It's not in stock and they don't have one. I ended up going with the one from Taormina Racing.
Here is a link: https://forums.pelicanparts.com/porsche-911-technical-forum/1107802-add-second-oil-filter.html
Old 02-14-2023, 12:16 PM
Evan Fullerton's Avatar
Careful buying from Taormina, I bought one, it never arrived……. Lots of other people out big money on the cases that never materialized.
Old 02-14-2023, 09:34 PM
No reverse gear in life
the 993 version from our host
https://www.pelicanparts.com/More_Info/99310705701.htm?pn=993-107-057-01-OEM
the 930 version from our host
https://www.pelicanparts.com/search/?q=930+107+057+01
David Alstadter - There is no reverse gear in life!!!
74 911 2.7 Carrera 9114400120 - licht grün
71 911T 9111121235 - recreated as 2.8 RSR glasur blau (3.0 MFI)
73 911S 9113301270 - silber metallic (sold)
72 911T - bahia rot (2.8 RSR) SCCA ITGT 95 LA & SD champ (sold)
Old 02-15-2023, 02:27 AM
proffighter's Avatar
Made same expirience, wanted to buy an used IC which was on their website, not available, but sent me a paypal invoice for another one (new) , 5times the price of the one I wanted
Roland
930 Turbo '81 Too many modifications to list
Old 02-15-2023, 02:32 AM
Originally Posted by dwa917 View Post
I have the 930 version on my 3.3l Turbo. Reason is the correct Filter OC 142 is longer and will probably not fit on the 993 console, not enough space to the oil inlet flange at bottom. If I remember correct, the shorter filter has no check valve inside.
Roland
Old 02-15-2023, 02:45 AM
What an amazing site, ask and thou shalt receive. Tocobill suggested RP and was correct and they delivered. Got it today. Thanks again for all that chimed in. It takes a village. Bob
Old 02-16-2023, 01:21 PM
