3.2 build without the flywheel based crank sensor question
I知 building a 3.2 and I値l be using clewitt pulley based crank sensor for itb痴 and was wondering if a 3.0 flywheel will work fine for this setup as I have one on hand. Any input appreciated. Thank you.
Old 02-23-2023, 03:06 PM
safe's Avatar
Yes
Magnus
Old 02-24-2023, 12:13 AM
It's a 914 ...
stownsen914's Avatar
As long as you don't need the stock sensors on the flywheel, then you'd be covered there with the pulley sensor.
It an early 3.2 with a 915? Then the 3.0 flywheel and your 3.2 clutch will work. If it's a G50 trans, you'd need to get a 225mm clutch that fits a G50.
Old 02-24-2023, 07:09 AM
So, Similar question...
I知 also "building a 3.2 and I値l be using clewitt pulley based crank sensor" for the stock style injection and twin plug. May be using 3.2 Motronic ECU, or moving to stand alone.. but will definitely be using the 3.2 injection either way as ITB's not in the budget at this time.
It's an early 3.2 with a 915.. is the 3.0 flywheel and 3.2 clutch doable with this situation also?
Any input appreciated here also. Thx
Old 02-25-2023, 06:30 AM
