Oil Pumps and locking tab washers
I'm beginning to reassemble a 964 engine and have a question about oil pump installation. In some of the older engines the oil pump nuts are installed with locking tab washers. With later model engines the locking tabs appear not to be used. Is a nylon locking nut sufficient for oil pump installs?
I never use a nylon lock nut inside a motor. Just buy the metal locking tabs and use them for peace of mind.
Tony |
Try not, Do or Do not
Hardened AN washer with prevailing torque nut.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Porsche calls them oval nuts, other names top lock, acorn et.
House producers wanted to end the show after season 8 to keep the enigmatic appeal of the central character and maintain the show's mystique. Ahhh The Mystique!!! |
Thanks to each of you for your responses
Metallic Lock Nut rather than Nylon Lock Nut. Belmetric dot com has many all metal lock nuts.
https://belmetric.com/nuts/all-metal-locking-hex-nut/ |
The prevailing torque in prevailing torque locknuts comes from localized plastic deformation to an interference fit with continuous sliding during assembly. Let's break this down.
Localized plastic deformation - Some of the starting threads need to be able to accept the mating part (bolt, say) before the prevailing torque begins. The interference is therefore localized to not include the immediate start of the assembly. For nylon insert locknuts, the interference is only in the nylon ring, and the metal part of the nut is free-spinning; but the interference is the entire internal circumference of the nylon ring. For all-metal locknuts, the threads are plastically deflected such that there are points of interference (1, 2, 3, or 6 points of interference, depending on the configuration of the deflection) with the threads of the mating part. ![]()
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 06-29-2023 at 03:49 PM.. |
Constitutional Liberal
The best part of this forum is that real Porsche engine builders offer information you may not be aware of. Although most don't need the "scientific" information, more is always better.
Jim “Rhetoric is no substitute for reality.” ― Thomas Sowell |
Henry is correct that’s why you should use the lock nut manufacturers compensated torque specs over the Porsche torque specs. We’re splitting hairs here for an oil pump however other applications are more critical.
Banned
I would love to read the NASA document calling for citric acid as thread lube. In my little corner of the aerospace world we often use citric acid to pasivate stainless, but this is the first time I have heard it used as a thread lube.
EngiNerding |
My error, it isn’t Citric Acid, we used Citric Acid to passivate stainless steel. The compound we used as previously listed for lubing fasteners was Cetyl Alcohol.
For those who don’t know or are inquisitive, passivation is used to remove the free iron molecules on the surface of a stainless steel part. Usually because of it being a new freshly machined part. We also used other acids to passivate like Nitrogen Tetroxide also know a N2O4. As far as NASA, I don’t recall using it when I worked on space shuttle. My experience with spacecraft for the NRO. And NASA is by no means the pinnacle of aerospace knowledge. NASA is more of a figure head for civilian US aerospace. NASA really doesn’t do much nor bring any technology to the table. Aerospace contractors are the ones who really work at figuring things out. Same with air force and any other military organization. They all hire contractors. NASA is no way the spokesperson for aerospace. Last edited by porschedude996; 07-06-2023 at 07:24 PM.. |
