2.0 Engine Case
This engine came into the shop for some upgrades. Interesting case....
michaelmount
Motorsports Engine Development (Retired)
Old 05-10-2023, 06:27 PM
PCA Member since 1988
Sure is purty. Expensive too!
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 05-10-2023, 10:12 PM
It's a 914 ...
stownsen914's Avatar
Nice looking! It has what looks like a Porsche part number, but it looks like a billet case.
Old 05-11-2023, 07:05 AM
Looks like polished magnesium. Maybe it has been through a micro-polishing machine. They use ceramic media in a vibrating drum with water or other lubricant. The process cleans and closes up the surface of the part. It helps prevent staining and other discoloration without changing any of the dimensions of the part.
1977 911S - high mileage and a bit rough but mostly original. Soon to become a bit of a hot rod.
Old 05-11-2023, 09:30 AM
Administrator
No, that's aluminum cut on a CNC machine
Old 05-11-2023, 07:24 PM
