Bill Verburg's Avatar
Originally Posted by Jeff Alton View Post
Bill,
Are you using the 3.6 base seals in the 3.8 block location? I got that sense based off the picture you posted of the 2 o-rings side by side. If so, that may explain. The seal Porsche produces for the 3.8 case is not round in profile, and they are available from Porsche. 999 705 023 41 is the part. Apologies if I miss understood the pic.
Cheers
The pics are oe 3.6 w/ Wrightwood seals, it's back together and dry, knock on wood
my 3.8 has the RS O-ring channel in the case
Bill Verburg
Old 08-03-2023, 06:46 AM
Jeff Alton's Avatar
Perfect, so you did use 999 705 023 41. Your 3.6 case was machined for the o-ring groove when the spigot bore size was increased, to match an original 3.8RS case, correct?
Cheers
www.turn3autosport.com
Old 08-03-2023, 04:39 PM
Cheers
correct
Bill Verburg
Old 08-04-2023, 07:20 AM
Originally Posted by Henry Schmidt View Post
ThreeBond 1211.
What head studs are you running and what torque?
I never have used 1211, what about Curil-T2 on the base gaskets? Your thoughts?
Old 08-13-2023, 08:37 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Curil T is our go to when a copper gasket is present. The use of 1211 seems to be a better choice if an o-ring is failing to seal.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 08-13-2023, 09:17 AM
