917_Langheck's Avatar
May not be polished, but in this pic the outer flange is not raw metal.
There are at least a couple of ways to check the shaft. One would be to set it in the case and check the backlash at various points of rotation as it meshes with the crank gear, as dannobee noted.
The other would be as Neil suggests, locating it between two centering pins, like on a lathe, and check all bearing points. (Maybe check the flange too, just for S&Gs).
____________________________
If it's not leaking, it's out of oel...
Old 06-21-2023, 02:05 PM
Try not, Do or Do not
Henry Schmidt's Avatar
In all my years of building 911 engines, we've only seen a few "out of spec" intermediate shafts. The bent shafts were entirely from engine that exploded.
Generally a rod failure where the rod stuck the shaft.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 06-22-2023, 09:21 AM
Reviving a good thread: What do you do when you have a new ims gear size 0, case size 0, crank gear size 0, and the back lash varies from 0 to 0.015 at different spots of rotation.
Bearings are new.
With case bolted and torqued, crankshaft and ims rotate fine by hand...
Had to fit a new IMS gear as the old was was thrashed by a chain when the tensioner collapsed...
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 02-20-2025, 09:47 PM
