SnapGap Tool Shims
The shims I received with the SnapGap tool I ordered were marked 0.10 mm but measured 0.04 mm thick with my digital caliper.
It is recommend the future customers measure the thickness of the shims they receive prior to installation. Lauran Last edited by RSOHC; 08-01-2023 at 08:54 AM.. |
Coram Deo
You may want to check your units. 0.1mm is 0.04 inches.
Corrected: 0.1mm is 0.004 inches. Thank you, Tony.
Dru 1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter • 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio • Last edited by RDM; 08-05-2023 at 01:25 PM.. |
Metrology………..
Lauran, Are you sure your micrometer is properly calibrated? I just did the measurements today of the Snap Gap shims provided are precisely at 0.10 mm (0.0039”). See pictures below: Snap Gap shim: ![]() ![]() Standard 0.10 mm filler gauge: ![]() ![]() I measured multiple times both the Snap Gap shim and the standard OEM 0.10 mm filler gauge and got identical measurements. Tony |
Decimal Point…….
Drew, Check your decimal point. 1.0 mm = 0.03937 in. 0.1 mm = 0.003937 in. Tony Note: Edited for typo. Last edited by boyt911sc; 08-01-2023 at 05:11 PM.. |
Racer
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
Typo……
I have measured a SnapGap shim with my micrometer rather than my caliper and have found that the shim has a thickness of 0.004 inches (0.10 mm) exactly as advertised by the vendor. I apologize for the statement that I made earlier.
Lauran |
