I’m living in Santa Maria. I had family in Palmdale and Land-Scatter. Quote:
I found my inductive bolt heater at the door this morning. I took the advice of LukasM and remembered the photo stand I made many years ago to take pictures of pictures. About 20 minutes I was ready to heat some studs.http://forums.pelicanparts.com/uploa...1696353142.jpg
http://forums.pelicanparts.com/uploa...1696353142.jpg http://forums.pelicanparts.com/uploa...1696353142.jpg |
Setup looks good! How did it work, have you tried removing any yet? Snap-on makes a new set of stud removers that are much more compact than the old collet style - both have their place however.
https://shop.snapon.com/product/Stud-Remover-Sets/10-pc-Metric-Stud-Remover-and-Installer-Kit/MSKM10 Here is my improvised setup so I don't have to stand around waiting: http://forums.pelicanparts.com/uploa...1696406801.jpg http://forums.pelicanparts.com/uploa...1696406801.jpg |
I have a knockoff set of stud removers just like the Snap-On one you have. There was another one that had a collapsing collet and a tapered nut. It broke, one of the collets snapped off. I ended up sending it back, I love Amazon. I’m only at day two. I did two cycles, maybe a couple more on some yesterday. I have to wait until Amazon sends a replacement. The heater quit working. I was only doing 20-30 seconds. It sparked a few times at the internal binding jaws. I had the knob tight, as tight as I could with my hand. Also the wire entering the jaws was hot enough to melt the shrink tubing on that side. It must have had some resistance at the clamping junction. Time to apply some penetrating oil. Three cheers for Amazon!!! |
I received a purchase of Inconel Exhaust Studs for Silverlake today. If you are familiar with ARP fasteners, you would know how wonderfully smooth a nut glides on their studs. Well, these Silverlake studs are not like that at all. They are so rough that a paper towel snags when brushed across the threads. The nuts thread on ratchety because they are poorly cut threads and not rolled threads. Inconel will gale just like stainless steel. Do I really what to induce a problem before they are run?
I ordered some studs off ebay, both Inconel and Titanium. I got both sets for just above the cost Silverlake ones. |
Exhaust Studs
I could only get three exhaust studs out using my stud remover. The other 9 are kicking my butt. I cut the studs off and left 1/8” proud. I then drilled out to 3/16”. I heated them up with my Rosebud and now i’m going to let them soak in liquid wrench for a day or two.
http://forums.pelicanparts.com/uploa...1696627314.jpg http://forums.pelicanparts.com/uploa...1696627314.jpg http://forums.pelicanparts.com/uploa...1696627314.jpg |
Exhaust Stud Procurement
I bought the Silverlake, I wasn’t happy with them. They took them back. I ordered believe it or not, on eBay. I got a couple different sets for the exhaust and a set for the intake.
A setback is always around the corner. I got all the studs drilled out to 3/16” by hand. I then heated the heads with a rose-bud and thought that temperature cycle and less material in the center would be a for sure thing. I then tried to step up the drill, but the material had hardened. I set it up in my mill and the stud laughed at the drills. I also tried some new cobalt drill bit and that was kinda working. I was able to get one hole cleared and then broke a cobalt bit off on the second hole.
I think my only path forward is to send them off to a specialist who can perform some (EDM) Electric Discharge Machine Removal magic. http://forums.pelicanparts.com/uploa...1696867096.jpg http://forums.pelicanparts.com/uploa...1696867096.jpg http://forums.pelicanparts.com/uploa...1696867096.jpg |
Put a steel nut over the stud, then weld it to the stud. While it's still hot, wrench out the stud.
If it's broken off flush, build up a little tit with the MIG welder so that there's enough material to then weld the nut to the stud. |
^^^^ This ^^^^ Surprising how well this works!
In the interest of not F’in them up, I’m sending 5 of the heads to a company call Jerry’s drill and Tap Removal in Santa Ana CA. The price isn’t all that much, 300-375. It’s worth it to me. I have plenty of other details to attend to.
Fuel Lines, chassis lines, fuel pump area, and CIS. Go through CIS. (hoses, clean, re-plate zinc items. Oil tank-regulator-lines. Rear suspension before I reinstall the engine. Powder coat engine tin. Engine assembly. Micro Polish exhaust system. And there will be more… |
I bought some Loctite 574 on ebay, every one likes it. Even Big Green.
http://forums.pelicanparts.com/uploa...1696953767.jpg http://forums.pelicanparts.com/uploa...1696953767.jpg |
Exhaust Studs
So which is though to be better? Inconel or Titanium?
Inconel for things hot.
Check the expiration date on your loctite. Does it really matter? No, but it's likely the reason why it was available on ebay. In aircraft or government maintenance departments, the date can get you dinged on an audit. |
I can understand that. I’ve never been through an audit Per Se. I have an A&P and worked for an aircraft manufacturer for many years. We had an Repair Station number and I used it to work on club airplanes.
I still have some Loctite from 15-20 years ago and it still works. I even have some “AA and AV” from my Aerospace days that will hold and take the threads out of a piece of metal, long before the Loctite gives up. Quote:
Head Studs
Here is my final configuration with the intake and exhaust studs. I went for inconol for the exhaust studs and titanium for the intake studs.http://forums.pelicanparts.com/uploa...1697164565.jpg
http://forums.pelicanparts.com/uploa...1697164565.jpg |
Funny Valve Adjusters
So in fine cleaning things for assembly and came across this oddity. Several tips of my rocker adjusters screws seem “Bent”. I can only conclude that the rocker tip of the adjuster was pushed hard over and bell mouthed. Any comments?http://forums.pelicanparts.com/uploa...1697246530.jpg
http://forums.pelicanparts.com/uploa...1697246530.jpg |
Titanium Studs and Nuts
Can you say Titanium studs and nuts? http://forums.pelicanparts.com/uploa...1697388736.jpg
http://forums.pelicanparts.com/uploa...1697388736.jpg |
Final Head Assembly
I got the heads back together after the stud removal using (EDM) ELECTRICAL DISCHARGE MACHINING
What a god send this process is. https://brokentap.com/services/ http://forums.pelicanparts.com/uploa...1698277973.jpg http://forums.pelicanparts.com/uploa...1698277973.jpg http://forums.pelicanparts.com/uploa...1698277973.jpg http://forums.pelicanparts.com/uploa...1698277973.jpg http://forums.pelicanparts.com/uploa...1698277973.jpg http://forums.pelicanparts.com/uploa...1698277973.jpg |
What's the coating on the inconel studs and nuts, seems like inconel is already pretty resistant to everything?
Sent from my Pixel 7 using Tapatalk |
I think it’s a black oxide.
Case, Crank, Clutch Return
I received the last of the subcontracted work. This from Competition Engineering in Lake Isabella, CA Cases cleaned, checked line-bore, oil galley plugs removed and bore scoped, oil squirters flow checked. Crankshaft plugs removed, passageways cleaned, micro polished (Still 0/0). Flywheel balanced, whole clutch, flywheel and starter ring balanced.
http://forums.pelicanparts.com/uploa...1698592727.jpg |
Looks purty. I love the sheen of polished machined steel.
Similar to the smells of a tire shop. Or gasoline from the 60’s. ;)
The Zinc Plating Begins
Doing some Zinc Plating and Yellow Chromate on engine hardware.
http://forums.pelicanparts.com/uploa...1699047195.jpg http://forums.pelicanparts.com/uploa...1699047195.jpg |
Final Cam Box Configuration
Here is the final stud height endeavor.http://forums.pelicanparts.com/uploa...1699048027.jpg
http://forums.pelicanparts.com/uploa...1699048027.jpg http://forums.pelicanparts.com/uploa...1699048027.jpg |
More Zinc Plating
Is your plating process from Caswell or someone else. They sure look nice!
Thanks, yes it is a Caswell Plating equipment. They can provide everything from Brush Plating to full commercial equipment. Plating and Anodizing.
Here is my setup. I built the lower electrical box, it is a Process Controller to control temperature. The Power Supply for plating is variable current. The liquid temperature which is not an exact science, but for predicting the final outcome, keep a constant and find the sweet spot on time and current. I’ve processed a lot of projects. The Yellow Chromate is used to Protect the Zinc, and the Zinc protects the Steel. http://forums.pelicanparts.com/uploa...1699665863.jpg |
I plan on sending all my sheet metal and engine mounts to a powder coater. Waiting on a quote back.
Meanwhile, more plating and now I started on the engine shroud and the fan. The fan was pitted and found a paint color that I like. Made by Ceracote, I’ve chosen Satin Magnesium. I still have a few pits I need to take care of on the fan. http://forums.pelicanparts.com/uploa...1699895306.jpg http://forums.pelicanparts.com/uploa...1699895373.jpg http://forums.pelicanparts.com/uploa...1699895435.jpg http://forums.pelicanparts.com/uploa...1699895480.jpg http://forums.pelicanparts.com/uploa...1699895480.jpg |
I built a small spray booth to paint some parts. I could have sent them to a body shop and been $$$ ahead, but i’ll use it for the remainder of my life.http://forums.pelicanparts.com/uploa...1702603546.jpg
http://forums.pelicanparts.com/uploa...1702603546.jpg http://forums.pelicanparts.com/uploa...1702603546.jpg http://forums.pelicanparts.com/uploa...1702603987.jpg http://forums.pelicanparts.com/uploa...1702603987.jpg http://forums.pelicanparts.com/uploa...1702603987.jpg http://forums.pelicanparts.com/uploa...1702604114.jpg http://forums.pelicanparts.com/uploa...1702604114.jpg More Zinc Plating, but the plating is almost finished. http://forums.pelicanparts.com/uploa...1702604305.jpg http://forums.pelicanparts.com/uploa...1702604305.jpg |
I got my tin back from my powder coater, along with the Cerakoted exhaust system components.
What is your background? Great to see you doing everything yourself.
Like many of us, live long enough and do just about anything.
Wrench and raced Motorcycles in my early years, Hot Rodding cars in my teens, aircraft manufacturer Flight Test Mechanic and then Field Service Engineer. Drag Racing. Worked on Space Shuttle then large satellites. Senior Staff Design Engineer on satellite handling and fueling equipment and transport equipment. So motorcycles, street cars, funny cars, Fuel Altereds, Gas Dragsters, airplanes, military defense fire units (Tanks), Scud Missiles, Titan and Space Shuttle Payloads, Aerospace Ground Equipment (AGE). Systems Engineer. Helped my two brother-in-laws build their houses, designed and built my 1,200 sq ft workshop almost myself, room additions on my house. |
More Zinc Plating
Finishing hopefully the last of the zinc plating in the next few days. Tubs of new and newly refurbished parts is growing. When I don’t have anything more to clean and refurbish it will be time to get to assembly.
http://forums.pelicanparts.com/uploa...1703543120.jpg http://forums.pelicanparts.com/uploa...1703543120.jpg http://forums.pelicanparts.com/uploa...1703543120.jpg |
Engine Assembly Sequence
Started assembling the lower end. Checked IMS end play, crankshaft end play, and IMS backlash.http://forums.pelicanparts.com/uploa...1706316197.jpg
http://forums.pelicanparts.com/uploa...1706316197.jpg http://forums.pelicanparts.com/uploa...1706316197.jpg http://forums.pelicanparts.com/uploa...1706316197.jpg |
I like what you did with the cam tower studs! Can you share the link to where got them and the sizes?
http://forums.pelicanparts.com/uploa...1707062601.jpg |
Nice job on the build, neat and clean. Careful with the sodium dichromate it is a carcinogen.
| All times are GMT -8. The time now is 12:32 PM. |
