Case Assembly
Cleaning up and about to join the cases.
http://forums.pelicanparts.com/uploa...1707447785.jpg http://forums.pelicanparts.com/uploa...1707447785.jpg |
Lower End Assembly
I got the case together today. No hitches. The Con-Rod and Chain holders I made worked well. Many years ago, 1986, I recall fishing everything through as I joined the case. Extra hands would have been nice, but none around at the time.
http://forums.pelicanparts.com/uploa...1707519237.jpg http://forums.pelicanparts.com/uploa...1707519237.jpg http://forums.pelicanparts.com/uploa...1707519237.jpg http://forums.pelicanparts.com/uploa...1707519237.jpg http://forums.pelicanparts.com/uploa...1707519237.jpg http://forums.pelicanparts.com/uploa...1707519237.jpg |
Very nice and clean work, fingers crossed that it stays dry, you certainly gave it the best chance!
I was looking at my photos and I didn’t take one of the sealant on the drivers side. I guess I started the sealant time clock in my head and subconsciously avoided the camera.
ARP Head Stud install
ARP Head Studs in. Cylinders to be installed tomorrow with the pre-appoved kitchen pass. I’ve earned hours of shop build time. I finished installing a new master bath granite vanity…
http://forums.pelicanparts.com/uploa...1707700342.jpg http://forums.pelicanparts.com/uploa...1707700342.jpg http://forums.pelicanparts.com/uploa...1707700342.jpg |
Nice built so far:)
As you are torquing heads soon: What torque you choose and why? According to ARP or lower as discussed here: https://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1155672-arp-head-stud-torque-value.html Br Roland |
Now you got me thinking. I had planned to go with what is shown in the bulletin from Parts Klassic. He has some good youtube videos and present well. Lots of experience, not unlike Henry and others. They all bring great things to the table. Problem with the layman, it’s more like a restaurant with a huge menu.
I didn’t find that whole piece of paper in my box from ARP. I saw a tech bulletin from Porsche thru PartsKlassic.com. https://www.klassikats.com/technical-service-bulletin-cylinder-head-torque/http://forums.pelicanparts.com/uploa...1707754281.png I think i’ll test the 11lb and 90 degree and check the final torque value on one head without the head gasket. In my profession, now retired, we tightened some fasteners on spacecraft in this angular fashion. I’m going to check with all the sources I can find and confuse myself further. Back to the restaurant, ask the waiter what’s good. ??? |
Henry, what are your thoughts and recommendations on head torque procedures?
I just tried the torque methods spelled out in Wayne’s book, the Bentley Manual 91SC, Technical Service Bulletin (86-13) from PartsKlasick, and the Porsche Technical Specifications book.
Wayne’s Book: Step One: 10Nm (7.4 lb ft) Step Two: 32NM (23.5 lb ft) Bentley: Step One: 15Nm (11 lb ft) Step Two: +90 degrees Porsche Technical Specifications book: Step One: 10Nm (74 lb ft) Step Two: 32NM (23.5 lb ft) PartsKlassic.com TSB 86-13 For Production Date June 30, 1986 https://www.klassikats.com/technical-service-bulletin-cylinder-head-torque/ Step One: 15Nm (11 lb ft) Step Two: +90 degrees I’m not sure of his numbering scheme, all the other Porsche Tech Bulletins are differently numbered. All the above come out the same, identical as I see it (on my not lately Snap-On calibrated torque wrenches). ARP: Step One: 19 lb ft Step Two: 38 lb ft The not so much shocker is the ARP. A bit of difference. It’s only 1.6 of the others ways above. But for the sake of conversation, ARP knows there stud reactions to pressure, tension, coefficient of material heat expansion. Maybe this the ultimate cure in my YM? Knowing your materials, their reaction to tension/pressure and heat is done better these days. Metallurgical studies today I believe to be far superior to old Porsche material science. At least more clearly. Not to bad mouth, but Porsche screwed the pooch with head studs on 2,7L year models. It has been ghosted for years. |
Cam Case and Head Assembly
Cams and Rockers
These went together swiftly. I used RSR Seals on the rocker shafts.
http://forums.pelicanparts.com/uploa...1707970915.jpg http://forums.pelicanparts.com/uploa...1707970915.jpg |
Pistons and Cylinders Install
Started installing the very first piston and cylinder and piston and broke a ring. Ahhhhhh!!!
I have a new Hazet Ring Compressor that I was using it upside down. The band that goes around the piston/rings is higher on one side. My cylinder was hitting a part of the handle and skewed cylinder and I broke the ring. About a 1/2” was broken off and I couldn’t find it. I bore-scoped it for an hour the first day. I had magnets on a stick down and around. I moved tote boxes and looked under, on, and around them. I looked at the expansion joint cuts in the concrete floor. I slithered on the floor for an hour. l wrestled with the thought that it’s not in the engine all night long. I had a hard time sleeping. I was sure it wasn’t in there but I was not moving forward without finding the 1/2” piece. I had my hawk-eyed wife out to help me. We both looked and finally I took a air hose and blew out the case from every angle. I was still using the air when my wife picked up the piece off the floor just below the engine. We did it, I really didn’t want to split the case. I ordered a single cylinder set of rings from pelican and should be here tomorrow. The other five went together with no problems. http://forums.pelicanparts.com/uploa...1708041839.jpg http://forums.pelicanparts.com/uploa...1708041839.jpg http://forums.pelicanparts.com/uploa...1708041839.jpg |
Cylinders and Heads Installed.
I got my replacement ring and installed the jug. My glossy powder coated baffles went on. Heads went on without any problems. ARP’s to 38ft lbs
http://forums.pelicanparts.com/uploa...1708138423.jpg http://forums.pelicanparts.com/uploa...1708138423.jpg http://forums.pelicanparts.com/uploa...1708138423.jpg |
Timing Chain Part 1
Cam Chain Cases are on. Using the Threebond 1184.
I was looking at the Stomski tool to tension the chain during timing, but thought of making my own adjustment tensioner out of my original spring loaded tensioners. http://forums.pelicanparts.com/uploa...1708308372.jpg http://forums.pelicanparts.com/uploa...1708308372.jpg http://forums.pelicanparts.com/uploa...1708308372.jpg |
Engine Assembly Continues
I got the engine all timed and sealed up. I borrowed a digital timing device and worked great. I think the numbers are good. I got both sides within (0.8 degrees). I tried either side of the pin hole that gave me .8 degrees and it was somewhere in the 3 degrees.http://forums.pelicanparts.com/uploa...1708917705.jpg
http://forums.pelicanparts.com/uploa...1708917705.jpg http://forums.pelicanparts.com/uploa...1708917705.jpg http://forums.pelicanparts.com/uploa...1708917705.jpg http://forums.pelicanparts.com/uploa...1708917705.jpg I was looking for a chunk of steel to set my magnetic holder for my dial indicator on to check TDC and found this lathe/mill fixture that i’ve had for decades and take a look at the hole spacing. |
Lucky you!
Tin Install
I finished the Tin install with my freshly powder coated gloss black tins. I went without the gloss so it’s easy to clean.
http://forums.pelicanparts.com/uploa...1709046732.jpg http://forums.pelicanparts.com/uploa...1709046732.jpg http://forums.pelicanparts.com/uploa...1709046732.jpg |
Brilliant idea with the 123 blocks, tell us about the digital timing rig. Nice job
Thanks, I was trying to hold a different straight edge and a vernier caliper at the same time and knew that wasn’t working when I kept coming up with different measurements.
The digital cam timing device was borrowed from a new friend on the forum. He generously offered and I took him up on it. If you’re interested I can ask if he wants his name in my post or would like to give people his handle. So the digital resolver fastens to crankshaft, and sends a signal via an either net cable (RJ45) to the display/controller. First you determine TDC using a dial indicator or a mechanical device that screws into the aft cylinder spark-plug hole. Cylinders 1 and 4. I used a dial indicator which I found easier. Then you zero the display. A dial indicator is moved to the intake valve of the bank you’re timing. Also very important to have the valve clearance as best you can. I also use the dial indicator for the valve adjustments of all the valves. Once you zero the dial indicator on the valve adjustment nut, you would rotate the crankshaft in the normal direction of travel until you teach your cam spec. My target number was .050” or 1.26mm lift. Once you get there, read the display on the device and you are looking for zero on the display, when your lift spec values are met. I was able to achieve .8 degrees. I tried using the cam timing hole on either side and came up with a higher value. I think it was in the 3 degree range. in my case the best I could achieve was .8 degrees because that is as fine an increment possible between the holes. You need to perform this on both sides. Two cams to time… Quote:
I had a setback yesterday. While installing the rear motor mount cross brace, I found it wasn’t fitting well at all. The brace is bent. I don’t recall it being bent when I sent it to my powder coater. I called and asked him if there was another set of 911 parts in his shop at the same time. We had a pleasant conversation and still couldn’t figure it out until i looked at the photos I sent for a quote. Yup, it was bent…
I don’t understand how it could be that bent. I came out that way. I ordered a new one. What’s another $$… |
Fan Shroud Install
Shroud fan and alternator went on with no problems.http://forums.pelicanparts.com/uploa...1709437715.jpg
http://forums.pelicanparts.com/uploa...1709437715.jpg http://forums.pelicanparts.com/uploa...1709437715.jpg http://forums.pelicanparts.com/uploa...1709437715.jpg http://forums.pelicanparts.com/uploa...1709437715.jpg |
More Assembly
Getting closer every day. I have a fan drag on the housing. I didn’t feel any play in the alternator before assembly. I think i’ll pull the fan and check for shaft play.
I am truly amazed by the complex beauty of these engines. http://forums.pelicanparts.com/uploa...1710342160.jpg |
Alternator FUBR
Another Set back. Fan was dragging Fan Shroud. Disassembled my Alternator and spun it up on my lathe to polish the slip rings. Bent armature… Run-out at least a .100”. I found a NOS made in 1993.
Nice work 996. http://forums.pelicanparts.com/support/smileys/wat6.gif
Thanks Discseven
http://forums.pelicanparts.com/uploa...1710817511.jpg http://forums.pelicanparts.com/uploa...1710817511.jpg http://forums.pelicanparts.com/uploa...1710817511.jpg http://forums.pelicanparts.com/uploa...1710817511.jpg |
Ya gotta stop admiring it, and start driving it!
:) I’m trying Pete!
What’s the saying? it’s not the destination, it’s the journey. I’m just sharing the fun experiences. Punch List: 1. Finish Engine CIS. 2. Join Engine and Transmission assembly. 3. Clear Engine Bay. 4. Replace Fuel Lines, front to back and CIS. (Len Cummins) 5. Pull and clean Oil Tank. 6. Disassemble, clean, evaluate the external oil thermostat. 7. Install engine. 8. Install axles. 9. Break in and drive it like I stole it??? Quote:
Bad Vendors
FYI, I’m having some problems with an e-bay guy. After purchasing a fan and shroud made by EPS from our host, I found them to be sub-standard. Real grainy surface on the shroud, and then the lip was polished (why???). The fan also returned because the surface color was modeled gray tones. I went on e-bay, dr911porscheparts is the vendor. I bought a shroud and fan from him. The fan and shroud were genuine porsche parts, but they were nasty. Fan shroud was pitted and had raised lumps from poor casting techniques. Beware of dr911porscheparts, he stated in my conversation with him that they were not the parts he sent. He stated he personally inspected them before sending. The styrofoam box was taped by Porsche and untouched until I cut the tape. His x-ray vision needs a cataract lens implant.
The reason I had to pursue the purchase was that I must have bent the housing when I installed it one of the times I was it out. I think that I didn't have it fully seated to the case and the roll pin hitting the shroud in the wrong place and when I sinched the shroud band it deformed the shroud. After all the turmoil with the shrouds and fans, I elected to try to straighten the shroud. Measuring the inside of the shroud, I found it to be about an 1/8" out of round as measured at the entrance curve about a 1/4" down the throat. I measured 90 degrees from each other stating at the high spot where the fan blade was hitting. Using a bottle jack and some small wood block I was able to get it straightened. Measuring the fan blade clearance, I came up with .008" difference. I was really worried about cracking the shroud in that it is made from a magnesium alloy. I guess the alloy was enough to allow it not to cause cracking. I think that if it was 100% magnesium that it would have cracked. http://forums.pelicanparts.com/uploa...1712252210.JPG http://forums.pelicanparts.com/uploa...1712171943.jpg http://forums.pelicanparts.com/uploa...1712171943.jpg http://forums.pelicanparts.com/uploa...1712171943.jpg |
CIS Lines 1
I am working on my CIS lines. Finally got the compatible parts. These are Frequency Valves. One on engine and a spare. I’m using a large electrical lug crimping tool.
http://forums.pelicanparts.com/uploa...1712362025.jpg http://forums.pelicanparts.com/uploa...1712362025.jpg http://forums.pelicanparts.com/uploa...1712362025.jpg http://forums.pelicanparts.com/uploa...1712362025.jpg |
You may be right Matt, I didn’t think of forgeries. The quality of the parts were, in my opinion, were sub-standard. These days it would be easy for an individual to have things made in China. He easily goes off the rails and makes accusations. Good choice to say clear.
I’m in the home stretch on the engine. Time to mate the trans and start preparing the chassis for insertion.
http://forums.pelicanparts.com/uploa...1713311125.jpg http://forums.pelicanparts.com/uploa...1713311125.jpg http://forums.pelicanparts.com/uploa...1713311125.jpg http://forums.pelicanparts.com/uploa...1713311125.jpg |
what yr engine & cis set up is this...?
looks great by the way... Nice job...!! |
Thanks Tweaks, it is a stock 1983 CIS.
Respect for all the work that you've done on your SC 👌
I decided to rebuild my '83 SC cabrio and started to rebuild my engine from US to EU specs, but doing that it gave me a lot off headbreakers and still does... Now I'm looking for a last part...a Bosch distributor 0237301009 (Electric part not the fuel part) but still can't find one..HELP If you have one (or perhaps know where this part is for sale) please let me know. I will bake a pie or two for you 😉 |
Hi Joblommie, thanks for the compliment.
The number doesn’t match what I used. The one that came out of my car and the Porsche Factory New has a different Bosch number. Both mine have Bosch 0.237.304.016. I purchased Porsche number 930.602.021.FX. The dealership here in the US bought it from Porsche. It looks like it sat on their shelf since 10/26/2012. I would check your numbers for the type car. I hope you find what you need. I bought mine from Checked Flag Porsche in Virginia Beach l, Virginia USA. The third picture is the one I rebuilt and ran for a couple of months before I decided to rebuild the engine. It is my spare. If you would like I can call them and see what they have or can get. Keithhttp://forums.pelicanparts.com/uploa...1715990240.jpg http://forums.pelicanparts.com/uploa...1715990240.jpg http://forums.pelicanparts.com/uploa...1715990240.jpg |
Hi Keith,
Your distributor, the 016, is the same that is sitting on my engine and is for the US ones. I need a 009 distrubutor wich are made for the ROW (Rest Of the World) SC cars. If you can ask your dealer, that will be great.. Like to hear from you. Thanks. Jo QUOTE=porschedude996;12251258]Hi Joblommie, thanks for the compliment. The number doesn’t match what I used. The one that came out of my car and the Porsche Factory New has a different Bosch number. Both mine have Bosch 0.237.304.016. I purchased Porsche number 930.602.021.FX. The dealership here in the US bought it from Porsche. It looks like it sat on their shelf since 10/26/2012. I would check your numbers for the type car. I hope you find what you need. I bought mine from Checked Flag Porsche in Virginia Beach l, Virginia USA. The third picture is the one I rebuilt and ran for a couple of months before I decided to rebuild the engine. It is my spare. If you would like I can call them and see what they have or can get. Keithhttp://forums.pelicanparts.com/uploa...1715990240.jpg http://forums.pelicanparts.com/uploa...1715990240.jpg http://forums.pelicanparts.com/uploa...1715990240.jpg[/QUOTE] |
Joblommi, I re-read your post. I missed that you were going to a Euro Spec. How about rebuilding and recurve the one you have?
Here is a link to your desired distributor. ROW https://www.klassikats.com/0237-301-009/ US https://www.klassikats.com/0237-304-016-1980-83-911sc-usa/ |
| All times are GMT -8. The time now is 12:32 PM. |
