-   -   Another 911SC Engine Rebuild (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1145425-another-911sc-engine-rebuild.html)
porschedude996 10-14-2024 06:13 PM
My Engine/Transmission is going in soon, real soon. Since my past com on this thread, I’ve been busy working on suspension, upgrading the A/C system (Griffiths), fuel system, brakes, lighting and electrical.
http://forums.pelicanparts.com/uploa...1728951527.jpg
porschedude996 10-15-2024 08:32 AM
Without my air powered hoist, my engine tilter, and hydraulic lift cart, I could not do it myself.
http://forums.pelicanparts.com/uploa...1729005819.jpghttp://forums.pelicanparts.com/uploa...1729006261.jpghttp://forums.pelicanparts.com/uploa...1729006366.jpg
Henry Schmidt 10-15-2024 08:57 AM
It may not matter but your engine crossbar is mounted backwards.
You might find fitting the engine mount bolts easier the other way.
BTW: you project is looking great.
porschedude996 10-15-2024 09:08 AM
Good point. it’s a new one, the original was bent and the holes didn’t line up with the engine tin. I was so happy the new one was centered on the divots in the tin. Not that I would second guess you Henry, but during my head scratching early on, I looked in the porsche parts manual and it doesn’t appear it has a lip… Anyway, I flipped it around just now. Thanks for looking over my shoulder.
porschedude996 10-16-2024 08:09 AM
Yesterday was a productively good day. I have a new appreciation for a “Partial Engine Drop”. I did some engine-body connections while 2-3 inchs lower than fully mated to the engine mounts. I could get to the FV if I needed to.http://forums.pelicanparts.com/uploa...1729090894.jpg
In the first photo you may spot the ratchet straps. I wanted to stabilize, although maybe over-kill, it did serve a purpose. The angle of the engine was flat as measured on the top of the transmission. When I needed to stab the transmission shaft into the cockpit, I was able adjust it angle during the process to point the nose up into the hole. I didn’t plan that at all.
porschedude996 10-16-2024 08:38 PM
I was looking through my photos of my car and found this old dinghy from June 2023 when I removed the power plant.
http://forums.pelicanparts.com/uploa...1729136300.jpg
Henry Schmidt 10-17-2024 07:15 AM
Originally Posted by porschedude996 (Post 12340739)
Well dude, that is a very impressive garage. Well done.
Of course this thread is about your rebuild and it is also very impressive. Looks like new.
I know because I worked on SCs when they were new.
PeteKz 10-17-2024 03:14 PM
Well? Where's the soundtrack?
porschedude996 10-19-2024 04:46 PM
I fired the engine and it started “ok”, but seemed off. I had an oil leak and a fuel leak. When it started, after the fuel got around to all the right places, it exhibited the typical warm up cycle i’ve studied about. After it was out of the warmup phase, it really didn’t like to idle. Ok, it started, a couple of leaks, no weird noises like a Harvesting Machine, I was happy for the day’s efforts. This afternoon I started with the basics with the CSI Gage set, timing light, and found the readings fine. Still not happy at idele. I got the smoke machine out and found everything smoke tight. Next thing was the CO meter and the Fuel Air Ratio. Both pointed mixture, lean mixture, like 30:1 and ranging. A simple tweek or four and ended up purring.http://forums.pelicanparts.com/uploa...1729381343.jpg
http://forums.pelicanparts.com/uploa...1729381234.jpghttp://forums.pelicanparts.com/uploa...1729381506.jpg
porschedude996 10-19-2024 04:47 PM
The duty cycle with the lamda plugged in 50%.
porschedude996 10-19-2024 05:57 PM
Sounds Happy to me.
October 19, 2024
https://youtu.be/uTgeWNOqiYg
porschedude996 11-25-2024 07:30 AM
The latest update. A few days ago, after spending countless hours trying to figure out the Duty Cycle, I found I flat screwed up! My Frequency Valve was not responding. I found that “I” had the FV and the Cold Start Connections reversed. When I assembled the engine, I recall the color coding wasn’t stupid-proof. I thought I had the correct positions, based on the curve set in the cables. Anyway, the planets aligned. Engine is running well, Duty Cycle is set, was responsive to the corrections I made on the fuel distributor.
I started another post about a wandering Duty Cycle yesterday. Sorry for being redundant,..
I’m thinking about purchasing Andrew Cologne’s CPU-Based ECU. Primarily to enhance the acceleration with better fuel ratio control.
28tbsfan 11-25-2024 02:34 PM
Looks great - I’m going on almost 2 years without my 89 911 with an engine rebuilder.
One thing after another….
QUOTE=porschedude996;12339208]My Engine/Transmission is going in soon, real soon. Since my past com on this thread, I’ve been busy working on suspension, upgrading the A/C system (Griffiths), fuel system, brakes, lighting and electrical.
http://forums.pelicanparts.com/uploa...1728951527.jpg[/QUOTE]
porschedude996 11-25-2024 08:14 PM
[QUOTE=28tbsfan;12364264]Looks great - I’m going on almost 2 years without my 89 911 with an engine rebuilder.
One thing after another….QUOTE]
Two years! That sucks…
PeteKz 11-25-2024 08:33 PM
Two years?? Demand them to give it back to you now, in whatever state it is. You can do it yourself much faster. If they give you any excuses, have your favorite lawyer send them a demand letter.
28tbsfan 11-26-2024 08:13 AM
It’s getting to that point. It’s too bad because this was once, from what I hear, a reputable shop. It sounds like a reoccurring theme with several customers. Their Dyno has been down for months and they blame it on the power company. Told me three weeks last week talked and when I called yesterday, they had done nothing.
G450X 11-28-2024 07:52 AM
2 Years…
Yikes, 2 years? The escalating costs, declining parts quality (and availability) and stories of countless shop delays give many of us with old high mileage Porsches needing a rebuild the chills.
I have been collecting parts for a pending rebuild for several years, but cases like this give me pause since my old SC always seems to start and drive fairly well even with high miles…
porschedude996 11-28-2024 08:04 AM
I would think that a shop that has a lease on their building would want to get the cars moving through and free up space. Floor space isn’t cheap.
porschedude996 12-09-2024 03:05 PM
Well I think everything is tuned correctly. I’m a bit amazed, even thinking I’m too lean on the Emissions Test that passed. Any thoughts on the values?
http://forums.pelicanparts.com/uploa...1733785505.jpg
PeteKz 12-09-2024 05:49 PM
Keith: Congrats on passing. Was the test at 2500 RPM on a dyno with load, or just sitting in the shop with no load? And congrats on getting it back on the road. I know it's been a long trip!
If it starts and runs well, don't mess with it yet. Give it some time and miles before trying adjustments. Go drive the snot out of it!
porschedude996 12-09-2024 06:37 PM
Thanks Pete, it was no-load test. I don’t live in an “Enhanced Area”. It does run better after running around. All street legal now. I put in a Fuel/Air Ratio Meter. I’m monitoring that gaining some experience.
dannobee 12-10-2024 08:39 AM
Blowing zeros is because of a properly functioning catalytic converter. Don't touch anything if it's running well.
Congrats on it back up and running!
Iceguy 04-03-2025 08:25 AM
Wow! Beautiful job, porschedude996!
All it took was an experienced mechanic. Not his first rodeo. Great garage, with lifts, hoist, engine lift, and engine and tranny mount. Access to some great service shops, and some great advice from fellow forum members.
15 1/2 months part-time including parts and tools finding, ordering and delivery. Full documentation including great photos. And a granite bathroom counter top.
Result: an essentially brand new engine, good for another 200,000+300,000 miles
Do you know many bucks for parts and services? Or do you not want to think about it!
porschedude996 04-03-2025 02:23 PM
Thanks Iceguy I finished putting in a Digital CIS O2 Control Unit. And a Auchtung Kraft Active Muffler is going in currently.
