-   -   Another 911SC Engine Rebuild (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1145425-another-911sc-engine-rebuild.html)
porschedude996 08-27-2023 10:57 PM
Hello, after purchasing my 1983 911SC almost two years ago. I’ve been working on getting things presentable. Mostly to feel good about the looks and inspire my hobby. I had all the dents taken out, cleaned trunk, interior, a couple of mods.
http://forums.pelicanparts.com/uploa...1693200970.jpg
I then started on a know problem Transmission, which was a disaster. That’s a different post… I was comfortable rebuilding it, got all the gears, Ring & Pinion, First Gear and Main Shaft, along with all the other gears short Reverse. With the R&P, I would need to have access to the the tools to set it up. I’m confident I could have done it, but couldn’t find a loaner. Adding an LSD.
http://forums.pelicanparts.com/uploa...1693201083.jpg
So while the transmission is off to California Motorsports.
http://forums.pelicanparts.com/uploa...1693201232.jpg
I decided to address the engine oil leaks. No broken head studs, but i’m replacing them for obvious reasons.
http://forums.pelicanparts.com/uploa...1693201418.jpg
So with the Cam Towers removed, took a look at the Cams and Rockers. Well those were pitted on a couple of lobs. And the rockers re-bushed, and the contact surfaces touched up. The Cams and Rockers sent to Dougherty Racing Cams for reconditioning and a 964 grind. Also found the Rocker Shafts were all worn, so new there also.
http://forums.pelicanparts.com/uploa...1693201575.jpg
I pulled the Spray-Bars from the towers to clean them out because of metal floating around. I never saw any metallic glitter when I first drained the oil upon my first service. I did find a chunk of brown hard sealant in the tube.
The valve seals were leaking and decided to have them refurbished. Probably Guides and Seals at the least. The guy I sent them to thinks the valves and springs are serviceable.
http://forums.pelicanparts.com/uploa...1693201679.jpg
So now to the Cylinders and Pistons. I pulled the and the Oil Ring Separators and totally carboned up. I checked the piston to cylinder dimensions and the measure .009”. They are Alusil Cylinders. I elected to buy Mahle Nikasil Euro 9.8:1 compression. They have about .0015 piston to cylinder clearance.
porschedude996 08-27-2023 10:58 PM
I also find the Lt Cam Chain loose. The IMS Gear had a tooth that was chipped about 1/4th of the tooth. Something was floating around in there. So the case was split and the good thing is the bearings look great. No specks lodged in the bearings. They were just a dark gray.
http://forums.pelicanparts.com/uploa...1693201824.jpg
http://forums.pelicanparts.com/uploa...1693201981.jpg
More about Cam Drive components. I’m changing all the Sprockets (6), Chains, Hydraulic Tensioners Update and Chain Wheel Supports, IMS Shaft assembly (Bearing Surface below limits). I bought as an assembly, Shaft, Sprockets, Gear, Bolts, even the cir-clip to prevent the oil shaft coupler in axial position.
I also disassembled the oil pump and saw some scratches in the rotors. I sent that off to Glenn Yee Motorsports. He refurbished, ported and polished. I also got the Updated Relief Valves from Glenn.
So currently i’m pulling all the studs from the Towers and Case to Re-Plate with Zinc and then Yellow Chromate. Hard to believe the piles of hardware on these engines.
The cases are going out to check line bore, through cleaning, and oil squirters. Also sending Connecting Rods. Trying to find a machine shop in So-Cal. Most have moved to Lake Havasu in Arizona.
mikedsilva 08-28-2023 01:01 AM
sounds like you're right on top of it. Should be a nice running motor when you're finished :)
Henry Schmidt 08-28-2023 04:42 AM
If CMS asks you to locate any parts for the transmission, give me a call.
We have everything you need. Don't forgot to update the tensioner arms.
We have new and rebuilt late model arms as well as out Supertec arms.
porschedude996 08-28-2023 06:53 AM
Thanks Mike, i’m going to need to take my wallet to the Emergency Room when i’m done.
Thanks Henry, i’ll definitely give you a call.
porschedude996 08-28-2023 09:37 AM
While extracting the Dilavar head studs i was trying different approaches to apply heat. At first i headed the case next to the stud i was removing and it seemed a bit slow to get the heat up enough. The aluminum case is a great heat sink, or heat sucker in this procedure. Mapp Gas is hotter than butane but it wasn’t enough. So I went to the stud and heated about an 1-1/4” from case. What is remarkable is the stud distortion while heating. After I got all the studs out, I was discussing with the experts here about my removals. Consensus is to never heat the bolt. And use an oxy-acetylene tourch on the case. Now I know…
http://forums.pelicanparts.com/uploa...1693240569.jpg
porschedude996 08-28-2023 08:41 PM
In looking ahead, I found an interesting bit of advice. I rebuilt a ‘72 911T 2.4L engine and the shafts leaked and was looking for a good explanation. I think 18-20 ft-lbs sounds good. I’ll try this and also use the rubber O-Rings, well not a circular cross section, more like a disk. My understanding is these were used in RSR’s.
Link to seals:
https://www.pelicanparts.com/More_Info/990579052.htm?pn=99-0579-052-M820&bc=c&SVSVSI=
http://forums.pelicanparts.com/uploa...1693280264.jpg
mikedsilva 08-29-2023 02:16 AM
Haha! Welcome to the club!
porschedude996 08-30-2023 05:34 AM
Line-Bore & Connecting Rods
Today spoke with Walt at Competition Engineering about him performing some magic on my project. From what he sees over his years in the Porsche world, with regard to 3.0’s & 3.2’s, he rarely sees the need to Line-Bore unless there was something catastrophic. Even with 150,000 miles on the clock.
Same with con-rods, even when going to ARP Bolts with higher clamping forces which in theory may distort the Big End hole. Reconditioning the con-rods is spelled out as necessary in the ARP literature that comes with a set.
He also stated the other end, at the wrist pin, rarely ware out. Previously I measured the wrist pin to con-rod rod clearance with my new wrist pins. I could only detect .001”. It was a less than ideal test rig, so the numbers are not 100%, but coupled with Walt’s knowledge, I feel good about reusing without re-bushing.
Today I applied this knowledge to my BE. I checked the BE of the rods at wrench tight, then at 50ft-lbs (ARP Torque Value), and then at .0095” to .0010” stretch value (ARP Spec). The bore of the BE never changed. The value torque value to get to the stretch .0095”- .0010” is 62ft lbs. So 55 to 62 ft lbs is sufficient to achieve bolt strength, top end of that is maximum bolt strength.
So my con-rods are cleaned and ready to go.
Chipping away one shoebox of parts at a time.
porschedude996 08-30-2023 05:48 AM
Cam Follower Installation
I started thinking about the cam tower assembly. I’m going with the dry installation. Maybe some window cleaner on the RSR seals to keep from damage during installation. The last 911 engine I rebuilt, I assembled the followers after head and tower installation. This time i’m assembling on the bench beforehand.
porschedude996 08-30-2023 05:59 AM
Engine Assembly Lubes
Thinking ahead again, my mind is all over the place. In the dozens of engines i’ve built over my years, i’ve always used a special lube on bearings and camshafts. Motor oil on most everything else. I know folks who only use motor oil to lube the bearings, and specialty break-in lubes on a new flat tapet cams. Otherwise only motor oil. The first Chevy Small Block V-8 (327ci) I dunked the piston with rings in a coffee can of 30w. I was the thing back in the day (hate that term, why???).
porschedude996 08-30-2023 06:17 AM
Piston Ring Clocking
When I purchased my Mahl Piston/Barrel Assemblies, I found them pristinely clean and nicely lubed. I was thinking they were ready to install. For those that have never know the proper way to assemble any IC Engine, the rings are clocked out of alignment with regard to the split of each ring to better hold the exhaust gases in the cylinder and oil in the crankcase. Usually 120 degrees out clocking. So given that, I found the spilt openings to be aligned with each other. So with looking at the top of the piston and the top to the intake direction (Up), i’m going with 1st compression ring at 10:00 o’clockish, 2nd compression ring at 2:00 o’clockish, First Oil Ring Scraper at 8:00 or 9:00 o’clockish, oil ring separator at 12:00 o’clock, and lower scraper at 3:00 or 4:00 o’clockish. I believe that is the preferred installation especially on a horizontally opposed engine to keep oil from worming its way to the combustion chamber and causing smoky startups. Please or correct me if you feel differently.
porschedude996 08-30-2023 06:22 AM
Startup Oil Question
I’ve seen it both ways. Detergent Oil or Non-detergent oil during initial start. An old question on any first fire of a rebuilt engine. Any thoughts from you smarties?
dannobee 08-30-2023 10:28 AM
Years and years ago, I watched a video on a development engine (single cylinder, lab setting) that had a marker applied to the back side of the rings, so that ring movement while running would show up on an x-ray machine. The rings were moving around pretty good. Sometimes as fast as 15-20 rpm, and not always constant, nor even in the same direction, depending on load and engine speed. After watching that, I concluded that being careful with ring clocking wasn't anywhere near as important as we all thought. But looking at any set of worn pistons and rings, you can see the wear as the rings move around the pistons.
stevie 77 930 08-30-2023 12:15 PM
Henry's tensioner arms are the ticket. Seen here with new, tensioners, chains and sprockets.
http://forums.pelicanparts.com/uploa...1693422874.jpg
porschedude996 08-30-2023 12:35 PM
Hi, thanks for sharing. Do you have any pics of them outside the installation?
stevie 77 930 08-30-2023 03:01 PM
Sorry, no other pictures un-instaled. But here is a one from a long time ago when i did my turbo motor back in 2010.
http://forums.pelicanparts.com/uploa...1693432690.JPG
Simply put, the machined bushing fits the shaft perfectly and when installed with the tensioner, there is a minimum of lateral movement (unlike using a spacer).
porschedude996 08-30-2023 03:40 PM
Ohhh, I had that wrong in my head. I was thinking it was the whole arm. What’s he get for the bushings?
stevie 77 930 08-30-2023 03:49 PM
The bushing is integrated into the arm to create the wide idler arm.
Lowo 08-30-2023 08:33 PM
I’m pretty sure this would be a nice motor once you’re done with it
porschedude996 08-31-2023 09:21 AM
Thanks Lowo
porschedude996 08-31-2023 09:35 AM
Is it Christmas?
Yesterday I got my cams and rocker arms, and Head Studs. Is it Christmas?
http://forums.pelicanparts.com/uploa...1693499071.jpg
porschedude996 08-31-2023 09:36 AM
Report on Cylinder Heads
I called on my Cylinder Heads and they are getting new guides and they should be ready tomorrow if the seats aren’t screwed up. Valves and springs are all good. He said these heads have never been touched. Man these 3.0’s are something else.
porschedude996 09-01-2023 04:26 PM
Getting Case Ready to Ship
I pulled all the case studs out to clean, zinc plate, and yellow chromate. Then I cleaned the thrust bearing and #8 and lightly greased them. Then greased the crankshaft and installed it the case to ship to Competition Engineering in Lake Havasu. Clutch cover and flywheel are going as well. I measured the HxWxL and found a Coleman Cooler to ship in. Sixty bucks on Amazon.
Case Cleaning, Case inspection, squirter cleaning, micro polishing crank, and balance the flywheel and cover together. About $700
http://forums.pelicanparts.com/uploa...1693703464.jpg
porschedude996 09-08-2023 09:25 AM
Interesting, I have to look for that one. I have seen videos of valves rotating in the head which was eye opening. The speed and direction changing and both valve spinning totally independent of one another.
If you find a link please share.
porschedude996 09-08-2023 03:49 PM
The Heads Return
I just received my heads that Steve Becker serviced. (Becker6.com) He does excellent work. I was amazed how fast he refurbished them and the look great. They only needed to have the guides replaced and the valves and seats touched up.
Wow! These Flat Sixes are made to run forever.
http://forums.pelicanparts.com/uploa...1694212974.jpghttp://forums.pelicanparts.com/uploa...1694213333.jpg
porschedude996 09-13-2023 02:48 AM
Exhaust Stud Headache
One thing I found out with regard to exhaust port suds, is don’t even think about pulling them. On the fourth stud, in snapped 1” above the head surface. then heated it with ocy/acetylene torch and snapped it flush. It’s a good thing i speak “Easy-Out” as a second language. I drilled it out dead center and tried to relax the remaining stud and it still wouldn’t come out. More heat, bigger drill and still wouldn’t come out. Finally I ended up drilling the hole to the normal size to start tapping a blank hole. it worked well and only got steel crips when i tapped it, no aluminum.
detroit 09-18-2023 11:23 AM
I pulled all the exhaust studs out my heads. Probably half snapped. I just welded nuts on them. The heat from welding yields the studs. They come out pretty easy after that...
porschedude996 09-18-2023 10:29 PM
Maybe i’ll try again. I just had the heads reconditioned and didn’t want to make the assembly lube run and burn. May disassemble one at a time. I have the tools and I rebuilt a set on my 911T some 35 years ago.
Detroit, what replacement studs are you using? I was hoping ARP made a set, but having difficulty find them during my limited internet access at the moment.
detroit 09-19-2023 05:26 AM
My plan was to use something in stainless, but Henry's Ti studs look pretty intriguing.
I'm using a set of Ben's headers though. The flange thickness differs from a factory manifold. I need to get that stack height defined before ordering anything.
LukasM 09-30-2023 01:02 AM
I disagree, I would remove all the 40 year old and very likely corroded stock steel studs while the heads are off and it's easier to do. If you have ever had an exhaust stud snap off while trying to remove the nuts to change the headers/heat exchangers, you will wish you had spent the $100-150 for a set of titanium exhaust studs, which basically don't corrode.
porschedude996 09-30-2023 06:37 AM
I have changed my view on leaving them and not replacing the studs. I’m not sure if i’ll go to ti.
dannobee 09-30-2023 07:17 AM
If you've ever looked at where exhaust studs really take the heat and rarely break, look no further that how Caterpillar puts studs on their over the road turbocharged diesel trucks. Looong studs, then the exhaust flange, then a spacer of about 1" thickness, then the nut. The added length of the stud allows the expansion to occur over the length of a much greater area than concentrating it right at the cylinder head/flange.
porschedude996 09-30-2023 08:28 AM
I’m not sure that is possible with the stock exhaust system.
porschedude996 09-30-2023 11:40 AM
I tried the Liquid Wrench soaked for two days and no success. I just purchased a magnetic induction heater for bolt and stud removal. I’ll see how that works.
porschedude996 10-02-2023 04:19 PM
Oil Spray Bar/tubes Orientation
I was installing the cam/rocker oiler tubes in my cam towers and found a clue to the orientation. The larger center two cross drilled holes in the tubes align with the recessed dimples in the tower. Of course the small spray holes go down into the cavities towards the cam.
http://forums.pelicanparts.com/uploa...1696288724.jpg
porschedude996 10-02-2023 04:35 PM
Exhaust Studs Redirection
After thinking I reconsidered replacing the exhaust studs. I choose to replace the studs and tried the usual penetrating oil and professional type double nut to extract said studs. I still didn't want to flame on with the valves and valve seals installed. I found a fastener heater and it will arrive tomorrow. I'll see how that goes. I ordered a set of studs from Silverlake Inconel studs. If you going to go, go big.
http://forums.pelicanparts.com/uploa...1696289302.jpghttp://forums.pelicanparts.com/uploa...1696289725.jpg
Dokeyi 10-02-2023 06:02 PM
Would really love to see this when you’re done, I’m pretty sure it would be nice
Madness 10-03-2023 04:24 AM
Looks like a solid build.
Do you have any specific power/rpm goals or are you simply documenting a solid build for posterity?
I'm from Palmdale California. What part are you in?
LukasM 10-03-2023 07:08 AM
That's a smart move! I have a similar induction heater with 1,5kw, works well to get the studs glowing cherry red. If you want to remove them I would try a few cycles of hot and cold, together with penetrating fluid, to break the bond and corrosion between the aluminum and the steel over a couple of days.
However the studs should then be cool when you try to extract them (hot they will be too soft). I like to heat up the entire head with a hot air gun (which I strap to a tripod as it takes a few minutes) and then cool off only the studs with freezing effect spray and a small nozzle.
You might still have one or two studs break but removing them in a mill now is much better than having them break in a few years when the engine is assembled and in the car, and you want to remove the exhaust.
Your inconel or ti studs will last a lifetime without worries.
