Reuse rockers w/ new cam?
Can I safely use old rockers with new cams? (Street engine)
TOT |
No, they will need to be reground or you’ll risk destroying your cams.
House producers wanted to end the show after season 8 to keep the enigmatic appeal of the central character and maintain the show's mystique. Ahhh The Mystique!!! |
Response
Dang that rabbit hole!
TOT |
New rockers through our host are $124 a piece without tax and shipping thus gets a little expensive times 12. I took all my rockers to a machine shop for steel bushing inserts, total cost for bushings and machine work was well under $200. Additional rocker grinding and polishing would be $300 for everything although I didn’t ask for regrinding as my cams were fine and my plan was to reuse them.
Try not, Do or Do not
Supertec rocker rebuild process:
We remove the old bushing and adjuster (if present) Clean adjuster threads with 8x1.0 forming tap. Black Oxide the rocker Ream the bushing hole Press in the new DP4 bushing and burnish Surface the contact pad Coat the contact pad with Moly dry film (TLML 2) Bore oiling passage Treat the rocker to a Cryogenic conversion process ![]() ![]() On the shelf ready for exchange
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Rockers
Thanks ……clearly the answer.
TOT |
Plus One on this.
Henry, what is the exchange price for a set? Also, what is Moly TLML 2? Couldn’t find it on the website. Quote:
Update
Old rockers shipped to Supertec today.
TOT |
Does anyone know the cost of the ticket exchange with Henry? I would like a set.
Clearly. But not in the website and no answer yet via email. I did think and try that first.
If you are going to put your services out there Id think a price would be helpful but what do i know.
1976 911 1976 914 1986 951 |
Constitutional Liberal
Call Supertec.
Jim “Rhetoric is no substitute for reality.” ― Thomas Sowell |
Prices
Agree….Henry is more than helpful and no muss no fuss. ……just call.
TOT |
i know web cams rebuilds them as well for about 800$ a set
I paid $35 each exchange at EBS $420
