Head studs and connecting rod bolts 3,2 engine
I am undertaking a full rebuild of my 3,2 engine. I know I have to change the head studs (my head stud has not broken) as a precaution. I have read that you should not use the dilavar studs.
I have been adviced to use the head stud (fully treaded), washer and nuts from a 993 turbo and the connecting rod bolts and nuts from a 964 turbo. Anybody who has any experiences of what to use?
Tor Erik Schjølberg
85 911 Carerra
83 Ford Capri 2,8I
Old 06-17-2004, 07:48 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Supertec Head stud kit. ARP rod nut and bolt kit. Race proven. These are the best way to go.
They are both available though Pelican Parts.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 06-17-2004, 09:25 AM
Thank you for your advice.
I found the Supertec Head stud kit, but I was not able to find the ARP rod nut and bolt kit. Do you know the parts #?
Tor Erik Schjølberg
85 911 Carerra
83 Ford Capri 2,8I
Old 06-18-2004, 08:37 AM
The ARP # is 204-6005. If you can't find them on Pelican Part's give me a call or email.
Henry Schmidt
Ph: 760-728-3062
Old 06-18-2004, 08:53 AM
