Engine rebuild?
Hi experts,
I recently bought a '71 911 T Targa with a 2.4 T engine (engine type 911/57). Although the engine was out of the Targa and the Targa needs a full restoration, the seller advertised the 911 with a high compression (good) engine.
Bought it for a good price and brought it home. Pulled the sparkplugs and on all 6 pistions I see this indent as in the picture enclosed. Not good I suppose (T pistons shouldn't have that I believe). Pistons/valves bad?
The engine doesn't have an engine number. The casing is the 7R casing. Was it modified wrong in its previous life?
1971 911 T Targa
1980 930 Turbo
2017 991.2 4S Targa
2023 Cayenne
Old 12-09-2023, 12:14 PM
al lkosmal's Avatar
pistons
RGruppe #669
http://www.x-faktory.com/
Old 12-09-2023, 12:32 PM
What plugs were in it when you pulled them?
Did they look stashed or did the PO change them?
I'm not picking my nose..I'm porting my upper intake manifold.
Old 12-09-2023, 02:49 PM
PCA Member since 1988
That divot is a valve clearance cut out. If it was an E or S, it would be deeper.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 12-09-2023, 05:23 PM
Thanks for the replies! When I looked up pistons for a 2.4 T online, I got some other, maybe standard piston images. But this helps me out. Thanks!
The plugs that I took out are Bosch Super W3CC and look ok.
1971 911 T Targa
1980 930 Turbo
2017 991.2 4S Targa
2023 Cayenne
Old 12-10-2023, 12:45 AM
Possibly a 2.2 t piston that’s been fit on the 2.4 crank giving low 9.3 CR
Bruce
Old 12-10-2023, 06:04 AM
