Case sealant
There is extensive thread and recommendation to use Threebond 1104……..however it appears it has been superseded by 1184 from search I did.
Does anyone have input/experience with 1184?
TIA
TOT
Old 12-11-2023, 12:58 PM
It's a 914 ...
stownsen914's Avatar
I believe the update is mentioned in the ultimate sealant thread or whatever it’s called. Pretty sure people just migrated to using 1184, but keep me honest and verify.
Old 12-11-2023, 04:15 PM
Sealant
10-4
TOT
Old 12-11-2023, 05:44 PM
Researched
You are correct.
1104 had lead in it so was discontinued. Superseded by 1194 then 1184.
Never realized so much research was necessary……but also funny….common comment was sealing surface cleanliness most important element of the process.
TOT
Old 12-11-2023, 06:34 PM
PCA Member since 1988
It always is.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 12-12-2023, 12:41 AM
Acetone is your friend.
I'm not picking my nose..I'm porting my upper intake manifold.
Old 12-12-2023, 03:34 PM
Just call them 11 series and 12 series threebond, since the numbers change so often.
11 series is thinner for metal to metal joints.
12 series is thicker and more for replacing a conventional gasket.
Old 12-12-2023, 04:17 PM
Sealants
Good explanation
TOT
Old 12-12-2023, 06:09 PM
Jeff Alton's Avatar
We are 20 engines into 1184, no issues.
www.turn3autosport.com
Old 12-12-2023, 09:28 PM
That's impressive! 20 engines in with no issues is quite a feat. Your current stable sounds like a fantastic lineup. Keep up the great work at Turn3 Autosport! 👍
Old 12-14-2023, 05:53 AM
Sealant
The thread you referenced is “The complete engine sealant thread” I’m not great with searches but was able to find it.
Tons of information including graphic of where each sealing compound is used.
TOT
Old 12-14-2023, 07:39 AM
Most sealants work for awhile. The real proof is whether they still hold after, say, 50,000 miles. Most of us will never know...
But I'm pretty sure the 1184 is at least as good as it predecessors.
Old 12-14-2023, 03:07 PM
The real proof is that billions of cars and motorcycles have used three bond RTV or its derivations or equivalent to seal up engines and transmissions for 30+ years now.
Old 12-14-2023, 04:05 PM
Jeff Alton's Avatar
Welcome to the forums. Don't be afraid to your use your real name.
Can't really tell if you are being facetious/sarcastic or not....
You did add some value on the 044 pump thread....
Was simply stating we have had Zero issues with the change from 1104 to 1184.
That said, we still use Loctite 574 on cam towers, because we had one engine years ago that leaked with the 1104/1184 on the cam towers. But, as you can see from the myriad of threads (and you seem to be in the industry) that every builder has their favorite sealants they used to reduce the risk to their reputation and limit the chance of a comeback, all based on our/their experience....
Looking forward to your contributions to this excellent enthusiast forum and community.
Cheers
Old 12-17-2023, 05:50 PM
